April 21, 2018, 10:14:02 PM *
Author Topic: Attaching Marble To Window Sills  (Read 2785 times)
« on: November 03, 2013, 03:18:44 AM »
What is a good product for attaching marble to a window sill the thin/set is not working it comes loose and I need a product that will not bleed through the marble got answers anyone ?
« Last Edit: November 03, 2013, 03:58:05 AM by luvrbus » Logged
« Reply #1 on: November 03, 2013, 03:52:07 AM »
I would try construction adhesive, probably a fast grab type.  You would have to test for bleed through, but the manufacturers recommend it for marble.
SPICEY MEATBALL
« Reply #2 on: November 03, 2013, 04:03:35 AM »
Ditto on the recommendation Clifford Wink clamp if possible.
Ex 1989 Model 15 Predator class War Bird owner
rip
« Reply #3 on: November 03, 2013, 05:33:18 AM »
When I had granite installed in my bus they used car bondo.I know it sounds strange but it has not moved in 11 years.The only thing I do not know if it will bleed through.If that will not work I would use pure silicone.
    Don
« Reply #4 on: November 03, 2013, 05:51:22 AM »
IF:it is porous on back GE silicon works great!  will have to chisel off.  Notice:  IF      That's what counter top people here use and I used in my coaches.  If it is to smooth on back might ruff it up to help what ever you use stick.  FWIW   Bob
Dave5Cs
« Reply #5 on: November 03, 2013, 06:58:30 AM »
Agree with Bob GE silicon. or backer board construcion adhesived down and then Marble Thin set. regular will not work.
Dave5Cs
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
« Reply #6 on: November 03, 2013, 06:54:41 PM »
I will "3rd" the clear 100% silicone....
There is not much that it won't hold!
