May 22, 2018, 03:20:39 AM *
Author Topic: using nitrogen with Pressure Pro?  (Read 4311 times)
jackhartjr
« on: November 05, 2013, 05:43:59 PM »
Hi folks, does anyone see an issue with using nitrogen with the Pressure Pro system?
Jack
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
Utahclaimjumper
« Reply #1 on: November 05, 2013, 06:03:06 PM »
 Your already using nitrogen,,, air is 87 percent nitrogen. The reason aircraft use it is nitrogen is moisture free so won't freeze at altitude.>>>Dan
« Last Edit: November 05, 2013, 06:04:58 PM by Utahclaimjumper » Logged
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #2 on: November 05, 2013, 06:06:47 PM »
Be very careful using Nitrogen if you use your own tanks, tank pressure is unreal.
Since air is about 80% N anyway using it doesn't seem to me to be worth the safety risk and I don't see how it could affect anything in a tire any more than would air.
« Reply #3 on: November 05, 2013, 06:32:43 PM »
Nitrogen won't make a bit of difference to your pressure pro system.  It also won't make any difference to your tires, but that's a whole different old wife's tale.
« Reply #4 on: November 05, 2013, 06:44:00 PM »
I take it this system is not for a bus ?
Jon
« Reply #5 on: November 06, 2013, 04:30:36 AM »
I flew a pressurized aircraft for 35 years and the only nitrogen used on the plane was to pressurize the gear struts. It wasn't because of moisture, but because it was a cheap source for pressurized gas that exceeded the shop air supply pressures.
The tires were filled with good old pressurized air.
Old wive's tale.
Jon
Knoxville, TN
« Reply #6 on: November 06, 2013, 04:49:17 AM »
Nitrogen has a % of water vapor doesn't it ?
jackhartjr
« Reply #7 on: November 06, 2013, 04:55:40 AM »
Clifford, right now the question is for my truck, it will also be valid for the Scenicruiser!!
Y'all laugh all you want, I have seen the documentation that it saves money over the long haul!
My diesel pickup has got me 90,000 miles on each of the last two sets using nitrogen!
The biggest savings is where you get a nail in a tire that you can't see. With nitrogen, it does not rust from the inside out, therefore the steel belts are not weakened. Which destroys the tire!
Jack Hart, CDS
8V71 Detroit
« Reply #8 on: November 06, 2013, 05:25:46 AM »
I don't know that much about it in tires I do know WalMart has used it for years on all their trucks and trailers tires and they have their own generators at the service terminals that removes the Oxygen making 95 % Nitrogen
I was told at my local Big O tire shop that if Nitrogen was not used in my tires @ 8 bucks each the tires would not have a warranty which I found out was total bs
« Last Edit: November 06, 2013, 05:46:25 AM by luvrbus » Logged
chessie4905
« Reply #9 on: November 06, 2013, 11:13:42 AM »
   You need to find out how many trucking companies use nitrogen. The nitrogen may not cause nails to rust, but what about the part of the nail that is in contact with the cords that isn't in contact with the nitrogen? How do you know that the truck tires may not have gone 90,000 with old fashioned air in them also? If your set on using it, go for it. I doubt that the pressure pro system would be affected with either source.
GMC h8h 649#028 (4905)
Pennsylvania-central
« Reply #10 on: November 06, 2013, 11:33:06 AM »
The rusty nail/belt story is new, I hadn't heard that one before! The N scam used to be it kept water out of tires and didn't leak as much as air??
chessie said it well, that experience does nothing to prove the worth of N.
It is like when a cold gets better in two weeks is you do nothing or 14 days if you take antibiotics!
What N does is make money for the gas companies.
Iceni John
« Reply #11 on: November 06, 2013, 02:32:21 PM »
Nah, nitrogen's over-rated.   I inflate my tires with propane, done it all my life, haven't blowed up yet.   When I needs to cook my roadkill for dinner I just puts an ol' rubber tube 'tween valve stem and BBQ grill, then voila instant tire-side cookin'.   What's wrong with that?
Just kidding . . .
I do agree though that there's very little, if any, incontrovertable scientific proof that 100% nitrogen is better in tires than the 78.09% nitrogen we all breathe.   As with most things, just follow the money.
« Last Edit: November 06, 2013, 02:52:51 PM by Iceni John » Logged
chessie4905
« Reply #12 on: November 06, 2013, 02:51:50 PM »
   Helium might be more beneficial. The blimps use it. If placed in the tires, would probably reduce gross weight of coach by at least several hundred pounds.........
Utahclaimjumper
« Reply #13 on: November 06, 2013, 03:40:11 PM »
 Jon,, I just retired after 33 years as an IA 36 years as an A/P & 21 years as a corp pilot and Director of maint. for two airlines and one helicopter company,I have owned dozens of aircraft mostly twins. Nitrogen is used in inflatable struts & in place of pure air in air over hydraulic struts to prevent internal corrosion and freezing at altitude, even at that it happens occasionally, and when the gear freezes in the wells things get noisy very shortly after coming over the fence..
 All jet aircraft today use nitrogen in the tire assemblies to help control temps. during high speed ground runs, BUT, I am NOT a proponent of using it in automotive tires.>>>Dan
« Last Edit: November 06, 2013, 04:06:42 PM by Utahclaimjumper » Logged
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
« Reply #14 on: November 06, 2013, 03:58:28 PM »
Really guys there must be some advantage to Nitrogen filled tires I never bought any Cat rubber tire equipment that was not Nitrogen filled at the factory why would they go to the expense ?
I did get tired of buying the stuff but Cat said the tires would have a longer life true or not I don't really know,all I remember is I would have nightmares for a week when I bought a set of tires for a 631 scraper at 32 grand a set lol
