May 20, 2018, 11:00:09 AM *
Pages: 1 2 [3]  All   Go Down
Author Topic: What size water / waste tanks are you using  (Read 7464 times)
harleyman_1000
« Reply #30 on: November 29, 2013, 08:36:02 AM »
If I figured it right I have a cylinder 90 gallon fresh water tank ( it measures 20" diameter and 65" in height., and a rectangle 120 gallon black tank that measures 15' high 28 wide and 64 inches long. Both tanks can be filled or drained from either side.
Scott
St.Louis Missouri
BCM Webmaster
« Reply #31 on: November 29, 2013, 09:06:16 AM »
By the way, in case anyone is interested and didn't know, there is a tank size/capacity calculator in the tools section of the BCM website.
http://www.busconversions.com/tools/rectangletank.html
Scott & Heather
MCI-9 & MCI-102
« Reply #32 on: November 29, 2013, 09:26:04 AM »
Here in AZ and other states the dumping of grey water is against the law,but the dumping of wash water (shower) is not a system with the kitchen sink tied into the tank where food particles are in the water is classified as sewage in most states just passing it on
But my neighbors dog can poop on my lawn every morning and evening. I don't buy into that silliness and hence have a hidden (routed next to the air tank between my rear duals) drain exit. 95% of the time, we have a sewer connection and it isn't an issue, but when parked on the side of the road or near parking lot drain, and showering, well...yeah.
Sent from my iPhone using Tapatalk. Clumsy fingers may contribute to mistakes.
Scott & Heather
dellisor
David M Ellisor
« Reply #33 on: December 01, 2013, 06:15:17 PM »
In my 4104 I have two tanks the fresh is stainless 140 gallons in an L shape and waste is also in an L shape but it is 150 gallons Both stainless ( made of Q qroup stafety related material lol )
Pages: 1 2 [3]  All   Go Up
