May 24, 2018, 04:44:02 PM *
Author Topic: Anyone Recognize this device?  (Read 3292 times)
Aviator
With enough thrust, Pigs fly just fine
« on: November 22, 2013, 07:43:37 PM »
Its located in the dash just above the door air dump valve.
It looks like a clock but only has one hand and the face is marked with three 24 hour periods  there is a red area over a couple of hours in 1 of the 24 hour periods.
Thoughts?  Could this be part of my mystery Webasto?   There are two wires out of the back but I haven traced them yet
Larry
Larry
1992 MCI 102C3
Northwest Indiana
Bill 340
« Reply #1 on: November 22, 2013, 07:51:06 PM »
Webasto
Bill & Brenda Phelan
Lakeland florida..........Host of the ARCADIA RALLY
« Reply #2 on: November 23, 2013, 09:06:23 AM »
Could be a aftermarket timer but doesn't look like any 7 day timers I seen for Webasto or ProHeat
« Reply #3 on: November 23, 2013, 12:16:51 PM »
That's the transfabulator modifier.
« Reply #4 on: November 23, 2013, 12:34:17 PM »
Webasto says that is a Quartz Clock Timer it's 1st time I ever saw one I thought they were all 7 day timers I did find a old schematic on the thing 2 wires is not going to cut it to make it work they show 11
« Last Edit: November 23, 2013, 12:44:51 PM by luvrbus » Logged
wg4t50
« Reply #5 on: November 23, 2013, 05:08:50 PM »
Yup, see where the Transfabulator modifier is required for the 11 wires, perfectly clear  Shocked
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
« Reply #6 on: November 24, 2013, 04:17:13 PM »
It's the timing device hooked to the right and left franistan that activates the automatic canutter valve to lubricate the right and left muffler bearing. Good luck, TomC
treeplanter
the grey ghost,1971 GMC 5305A
« Reply #7 on: November 24, 2013, 04:38:25 PM »
DO NOT hook up those wire's to the wrong terminal or your bus will travel back in time!
Timothy
Aviator
« Reply #8 on: November 26, 2013, 11:34:37 AM »
Maybe i can make the bus a time machine with this thing.
When this baby hits 88 miles and hour your gonna see some serious S**T  !
Larry
Larry
1992 MCI 102C3
Northwest Indiana
« Reply #9 on: November 26, 2013, 02:28:51 PM »
really think that is the tail flap control---sorry wouldn't resist.. do we have a winner?  I have no clue?
« Reply #10 on: November 27, 2013, 02:16:45 AM »
Where you able to fire the Webasto since the timer was identified ? just curious
« Reply #11 on: November 27, 2013, 03:15:34 AM »
Thank you for clarification!  was getting a little confusing...and have heard more off wall   things on equipment that could be possible.  Bob
Aviator
« Reply #12 on: November 27, 2013, 08:09:27 AM »
Luvrbus
I havent' got that far yet.  However I do know the timer LED blinks green when its armed and the timer runs.
I haven't let it try to start the Webasto yet because I haven't had to time to properly supervise it's lighting.
I'd rather not have the bus creating any kind of fire when I'm not around.
Larry
Larry
1992 MCI 102C3
Northwest Indiana
