February 24, 2018, 03:59:49 PM *
Author Topic: Need Bendix numbers for dd3 diaphragms  (Read 2739 times)
thomasinnv
Derrick Thomas
« on: December 14, 2013, 05:49:36 PM »
I have a 1977 MCI MC8 and I am looking for Bendix part numbers for the following diaphragms for rebuilding my DD3's:
I am looking for the Bendix numbers for the service diaphragm MCI #4C-5-20 and the auxiliary diaphragm MCI #4C-5-21
I'm sure someone on here has the Bendix numbers. Many thanks.
Sent from my HSG1279 using Tapatalk 4 Beta
1998 MCI 102-DL3
Series 60 11.1/Alison B500
wildbob24
« Reply #1 on: December 14, 2013, 06:33:06 PM »
Service diaphragm is 292711
Auxiliary diaphragm is 246675
May not help much as Bendix no longer supports the DD3.
Mohawk sells them in sets.
Bob
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
Greenville, GA
thomasinnv
Derrick Thomas
« Reply #2 on: December 15, 2013, 06:43:02 AM »
Any idea what the part number is for the set from Mohawk? Neither the mci numbers or the Bendix numbers bring up any results
Sent from my PantechP9070 using Tapatalk 4 Beta
1998 MCI 102-DL3
« Reply #3 on: December 15, 2013, 10:17:59 AM »
There is only one thing you need to remember:
CLF
CALL LUKE FIRST
chessie4905
« Reply #4 on: December 15, 2013, 02:46:08 PM »
   GMC ( from my 4905 parts manual) is listed as a kit of both diaphragms #668324. Mohawk bus parts site: supersedes this number by #2023416 then superseded by 2037901. Result says that it is no longer available. I'd give them a call to see what they suggest; they're a family run operation and very helpful.
   You have to do the search by starting as KIT, then #668324, then GMC in the three lines. If you start with either superseded part number first, you won't get any results.
GMC h8h 649#028 (4905)
Pennsylvania-central
« Reply #5 on: December 15, 2013, 03:03:31 PM »
John @ Bus Services had the parts and was quite a bit cheaper on the diaphragms than others 785-891-3741 Jefferson had those also a few years ago he may still have the parts a lot of older Eagles still have the DD3 brakes
Cary and Don
« Reply #6 on: December 16, 2013, 09:13:25 AM »
We just took them down to Napa and they matched them up.  I think they were about $40 each for the service when we bought them.  Took two days to get them. The others they had in stock on the shelf.
Don and Cary
1973 05 Eagle
Neoplan AN340
thomasinnv
Derrick Thomas
Re:
« Reply #7 on: December 19, 2013, 03:45:09 PM »
I ended up getting them from Luke. I called Mohawk and they are in fact no longer available from them.
1998 MCI 102-DL3
