February 22, 2018, 05:01:56 PM *
Author Topic: Honda EU3000IS auto start from inverter panel  (Read 6157 times)
Oregonconversion
« on: December 17, 2013, 08:51:28 PM »
I have the xantrex RV3012 inverter and I am STILL looking for a generator. All I really need is 2500 watts but I want the inverter to auto start up the generator and charge the batteries then shut it off.  Has anyone done this?
I know there is an auto start kit you can buy that comes with an auto choke. I know I will need the auto choke for sure.
I just want to make sure its possible before I buy the generator.
1977 MC8
8V92 HT740
Oregonconversion
« Reply #1 on: December 17, 2013, 11:32:09 PM »
http://s34.photobucket.com/user/111saltwaterredneck/library/Honda%20EU3000is%20remote%20start?sort=6&page=1
BAM!
1977 MC8
8V92 HT740
« Reply #2 on: December 18, 2013, 01:15:20 AM »
Ok, but how would the inverter trigger that?
wg4t50
« Reply #3 on: December 18, 2013, 01:39:33 AM »
Auto start of a gasoline engine used for generator use is nearly impossible to have a smooth system.
Reasons are;
1-How much choke is required warm days and cold days?
2-Usually if the engine startsit can not take much load with the choke on to some degree.
3-Gasoline powered engines used on generators are fine if you start manually and wait until it warms up enough to get choke fully off, then apply the load.
4-None of this makes a happy auto start setup.
5-Other than being real cheap, WHY a gasoline powered unit.  Gasoline is by far the poorest fuel for a happy generator.  Go LP Gas or Diesel, you will be a happier camper for sure.
6-Gasoline will use twice as many gal of fuel than the same size diesel.
BTDT
Dave M
« Last Edit: December 18, 2013, 03:30:45 AM by wg4t50 » Logged
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Oregonconversion
« Reply #4 on: December 18, 2013, 07:47:54 AM »
Thanks Dave, I'll keep that in mind.
1977 MC8
8V92 HT740
Ralph7
« Reply #5 on: December 18, 2013, 08:11:02 AM »
   I have a 3000is Honda and the exhaust is a major problem!!!!!!
    I bought an APU by Rig Master, it has an auto start, used units $1500-3000.
    They are
a 2cyl. 500cc diesel, the engines are built in Japan with Perkins name on it.
oltrunt
A fine BCM outting
« Reply #6 on: December 18, 2013, 06:00:06 PM »
Hello All.  I installed a Yamaha EF3000iSEB genny in an enclosed box below my bus.  The genny had a manual choke which I replaced with a solonoid operated choke run through a thermocouple (to detect eng temp) and a relay.  Although this isn't an auto start it sure would lend itself to such a system.  So far this has been no problem and I get instant start and no smoke or backfires with just the flip of one switch.  Hope this helps.
Oregonconversion
« Reply #7 on: December 18, 2013, 06:11:31 PM »
Thanks Oltrunt,
Did you make your own exhaust pipe? If so what did you use?
1977 MC8
8V92 HT740
oltrunt
A fine BCM outting
« Reply #8 on: December 18, 2013, 06:45:31 PM »
Hey Oregon,  Yes I did make a new exhaust system.  I simply could not push enough air through the genny box to keep the oil temp in the genny below 200 degrees F without moving the muffler out of the box.  The exhaust port at the cyl head called for 5/8" pipe so I made up a little head pipe from steel pipe and clamp connected flex pipe (from Mc Masters and Carr) to that.  I routed the flex through 1 1/2" exhaust pipe from the genny box to the oposite side of the frame where I connected the flex to the original muffler.  I then used thin wall 5/8" steel tube as an exhaust pipe to the rear of the bus (about 10')--much cooler and even quieter.
As an aside, I had mounted the genny on half a dozen valve springs to help dampen the genny vibration.  This works good except when the genny first starts.  Upon start up the genny "jumps around" a bit until it is completly lit.  This caused the flex pipe to strile the exhaust tubing which made quite a racket.  I solved the problem by wrapping the flex pipe in high temp silicone radiator hose  and stuffing it back into the exhaust pipe material.  Problem solved.  I selected mild steel flex but I'm sure that stainless steel would last much longer.  Jack
hargreaves
1987 MCI 102A3
« Reply #9 on: December 19, 2013, 08:59:17 AM »
Does your inverter have a generator auto start mode?  If it does it should start the generator no problem . The hondas start good in all kinds of weather. I have a xantrax 2412 and a honda ei 5000. it starts the generator no problem. I can manually start it from the panel, have it start from low battery voltage or set the load amps to start it. can also build a delay into the start up time.  I love it! it works seamlessly .
cheers Gerry.
LuckyChow
« Reply #10 on: December 19, 2013, 09:28:55 AM »
cheers Gerry.
Gerry, I was going to look at your Honda ei 5000 on line, as I'm not familiar with that model.  Can't find a reference.  Is this a typo?
Darryl
Smyrna GA
2000 Gillig Phantom
« Reply #11 on: December 19, 2013, 11:38:35 AM »
I have the Yamaha 3000 as well, thanks for the tip about remote mounting the muffler.  I carry mine in the AC condenser bay but it gets way too hot even in there.  Anyway, there is a factory remote start kit for it.  Uses a radio remote key fob, as I recall.
hargreaves
1987 MCI 102A3
« Reply #12 on: December 19, 2013, 03:54:12 PM »
Ya sorry its the eu5000 is same as yours but 5000 watts.
« Reply #13 on: December 20, 2013, 08:16:12 AM »
Honda doesn't seem to make an EU5000.  Are you sure it isn't an EM 5000, or an EU6500 which is actually 5,000 watts continuous?
