April 21, 2018, 10:25:20 PM *
Author Topic: My GM 4104 6v92 T-drive  (Read 2240 times)
harleyman_1000
« on: December 22, 2013, 01:22:13 PM »
[/img][/img][/img][/img][/img][/img][/img][/img][/img][/img][/img][/img]
Scott
St.Louis Missouri
harleyman_1000
« Reply #1 on: December 22, 2013, 01:23:02 PM »
How the hell do I upload a picture on this site?
Scott
St.Louis Missouri
« Reply #2 on: December 22, 2013, 03:22:54 PM »
You click on the "Additional Options" link at the lower left of the message space.  You click on "browse".  You go to the location of your picture in your computer and click on the file name of your picture, then you click on "Open".  It has to be smaller than 196kb.  That brings you back to the message with the attachment included in the "Additional Options" menu.  Then you hit send.
« Last Edit: December 22, 2013, 03:28:06 PM by bevans6 » Logged
« Reply #3 on: December 22, 2013, 08:40:33 PM »
8V turbo looks good. Would suggest you add an accordian section to the exhaust pipe for expansion and contraction-will save your exhaust manifolds from cracking. That flat piece on the top going from the left to the right side would be a prime place to install the accordian piece. Usually stainless is used-but is expensive. Good Luck, TomC
