February 25, 2018, 02:01:44 PM *
Author Topic: Smoked clutch I think  (Read 4468 times)
5B Steve
« on: January 04, 2014, 02:36:35 PM »
  I tried to move the bus today ,she moved forward about 2-3 feet stopped, reverse 2-3 feet, when I went in to
 gear again , nothing.   Did the clutch let go?  Tires didn"t spin.
  Steve 5B......
« Reply #1 on: January 04, 2014, 03:47:01 PM »
maybe out of adjustment, but I don't see that short bit of moving as a way to burn up a clutch,
maybe stuck in neutral ??
Donald PH
« Reply #2 on: January 04, 2014, 03:53:13 PM »
The splines on the driveshaft slip joint may be gone, happened to me.
« Reply #3 on: January 04, 2014, 03:54:04 PM »
Probably the assist is hung up in a neutral position not letting the clutch engage
5B Steve
« Reply #4 on: January 04, 2014, 05:57:54 PM »
 If that's the case, how do you fix it?
  Steve 5B.....
« Reply #5 on: January 05, 2014, 03:55:11 AM »
If the air assist cylinder was hung, the clutch pedal would be stuck on the floor.  Do you have a normal clutch pedal movement and pressure?  Can you get someone to press on the pedal while you look at the linkage on the gearbox to see if everything is moving right?  Are you sure you are getting it in gear properly?  Has the reverse solenoid hung up at all or is it operating correctly?  You can see the reverse solenoid and the top of the clutch linkage through the access panels in the floor at the back of the bus.
« Reply #6 on: January 05, 2014, 04:19:32 AM »
Just press the pedal without air if you don't have about 2 inches of free play on the pedal start checking beginning with the adjustment in the rear side door, the assist pivots and will hang in upwards position or the level position from time to time is what I find
There is a bunch of linkage and circuital adjustments associated with the air assist fwiw that is where I would start JMO they never get greased
« Last Edit: January 05, 2014, 08:10:50 AM by luvrbus » Logged
PP
Will & Wife
« Reply #7 on: January 05, 2014, 08:08:48 PM »
If the clutch failed, wouldn't it be almost impossible to get it into gear? Just another dumb question-it's past my bedtime.
Will  Smiley
« Reply #8 on: January 06, 2014, 03:47:21 AM »
Lots of ways for a clutch to fail but two of the most popular are for the friction lining to burn up and causes massive slipping.  If it can't engage at all, you could still put it in gear but you'd still feel the clutch spring there.  The other way (seen it on race cars but no idea on bus clutches) is for the center to rip out of the clutch disc so the engine is basically not connected to the input shaft any longer.  Without more information from Steve it's hard to guess what's happening in this case.
« Reply #9 on: January 06, 2014, 04:03:19 AM »
A broken axle will give him the same symptoms fwiw
5B Steve
« Reply #10 on: January 06, 2014, 08:34:49 AM »
   Thanks for all the info everyones' posted. With the weather in the indianapolis area today --12 it will have to wait
   untill later.  I will post then, Thanks again!
    Steve 5B....
Utahclaimjumper
« Reply #11 on: January 06, 2014, 10:18:33 AM »
 A broken axle, stripped splines, broken clutch splines, all will generally make a lot of racket. More than likely the clutch is hung and is not engaging.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
