February 21, 2018, 03:42:19 AM *
Author Topic: 12 volt floresent ballast  (Read 4264 times)
uncle ned
« on: February 24, 2014, 10:55:56 AM »
Looking for several 12 volt florescent ballasts. for huggy.
Momma need to see how to cook. they are over the stove and sink.
uncle ned
4104's forever
6v92 v730
Huggy Bear
« Reply #1 on: February 24, 2014, 11:43:03 AM »
Do you mean replacement ballasts for existing fixtures, like these, or new fixtures?  Regardless I was surprised at how expensive they are, same price I paid recently for 120V 120 watt ballasts.  I use 12v in my bus, I have a spare or two but saving them...
http://www.powerstream.com/ballast-1.htm
« Reply #2 on: February 24, 2014, 02:12:20 PM »
 Ned, go to 12v Led tube lites, fit in the same place, use less juice, last way longer and don't need/use a ballast. They are just as bright if not brighter.
« Reply #3 on: February 24, 2014, 02:31:51 PM »
If you are looking for the 12 volt ballast for the Thin/Lite they cost 21 bucks each @ Northern AZ Sun and Wind fwiw not long ago Thin/Lite would replace the complete lite for 15 bucks I think they have stopped that now but not sure
Jerry32
« Reply #4 on: February 24, 2014, 03:18:40 PM »
I replaced my flo light with leds and much brighter and less current. Chinese led panels with 48 leds on them stacked 4 per light work very well. Jerry
1988 MCI 102A3 8V92TA 740
uncle ned
« Reply #5 on: February 24, 2014, 04:33:08 PM »
They work with the t type florescent bulbs  the ones with one tip on each end. I think they came out of transit buses
They have three wires coming out of them  white red and black.
Black is ground
white to one end of the bulb
red to switched 12 volt and the other end of the bulb.
uncle ned
4104's forever
6v92 v730
Huggy Bear
PP
Will & Wife
« Reply #6 on: February 24, 2014, 05:23:26 PM »
Northern Az Sun and Wind-I've had to replace 3 of mine so far. Much cheaper than buying the whole light fixture. Now that I've used my spare I too will be going to LED in the future.
Will
Homegrowndiesel
Vegetable oil, Rudolf Diesel's original fuel
73-05 Eagle
« Reply #7 on: February 24, 2014, 05:36:33 PM »
Try some of the COB, "Chip on board led" I have found these to be the best.
Aerodynamic Eagle & MCI 102a3, 102d3 and NABI series 50 transit. Busnut x4
Homegrowndiesel
73-05 Eagle
« Reply #8 on: February 24, 2014, 06:15:56 PM »
direct 12-30 volt dc, depends on
  Depends on how
how you want to use Your Bus.
with COB Led's you will have a more,
more diffused light , and best watt to lumen output. I have never reached 1/3 of their life expectancy in the standard led "bulbs" but have better expectation on these chip on board "COB"  ceramic backed led"s. "I Feel" the ceramic can cool the assembly enough to get the expected life" Either way, I like the diffused, reflected light as well as the direct task light. Each to their own.
  Anyway, You already have DC voltage there. try some cheap, low watt drawing led's  I have some mr16 bulb bases if you want to check them out. I bought 20 for I think $5.00 ,  so I have plenty left. I used them on my pizza spotlights. Hmm,, Pictures.
bs4104
« Reply #9 on: February 24, 2014, 06:33:47 PM »
How long are your floresent bulbs, & one or two on a ballast?  what the number on the bulbs?Huh?
Bruce
102A3 N14 Auto Shift
Homegrowndiesel
73-05 Eagle
« Reply #10 on: February 24, 2014, 06:52:09 PM »
http://www.ebay.com/itm/131095671955?var=430262580378&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2648
http://www.superbrightleds.com/moreinfo/empty-bases-sockets/led-product/499/2027/?utm_source=googlebase&utm_medium=base&utm_content=MR16S&utm_campaign=GoogleBaseChild&gclid=CL2qtMSk5rwCFW3xOgodCUwA3w
These led bulbs run off 12 volt dc. no need for ballast. just wire in direct to your breaker. use as diffused light left to right, behind window shade. Or as direct
« Reply #11 on: February 25, 2014, 07:47:57 AM »
What kills those ballast is low voltage I have some florescent 12v in a 1985 Coachmen that have never been replaced,then on the Eagle it seemed like I was always replacing a ballast once the batteries started to age
goutoe
« Reply #12 on: February 25, 2014, 10:16:09 AM »
I have those same ballasts in my bus, I tried hard for over a year to find replacements, the only ones I found were not heavy enough to supply the watts needed, so I have been replacing the floresents with LEDs I am very pleased so far.>>>> John.
John & Linda 1977 AM General 6V92 turbo Detroit 3 Speed allison, 40 ft.
PP
Will & Wife
« Reply #13 on: February 25, 2014, 12:29:34 PM »
Bruce
Mine are the 18" double bulb style recessed into the ceiling. I have 14 fixtures total (I think- I lose count when I have to take my shoes off-toes, fingers, it's like using 2 computer monitors) HTH
Here's the link to the exact ballast that I used:  http://www.solar-electric.com/tl-ib-116.html
Current price it 21.98. I might have a hard time switching to LED because I picked up a case of 18" bulbs at a home recycling place--more than 30 bulbs for 5. bucks. All new too.
Will  Cheesy
« Last Edit: February 25, 2014, 12:43:52 PM by PP » Logged
uncle ned
« Reply #14 on: February 25, 2014, 01:53:59 PM »
I am running 2 f48t12d  in series off one ballast.
also running 2  twice a long.  found new bulbs in Tenn with bk.
can't find the ballast yet
uncle ned
4104's forever
6v92 v730
Huggy Bear
