January 16, 2018, 01:39:52 PM *
Author Topic: heat  (Read 1388 times)
codretaw1
1965 mci 5A south lyon, michigan
« on: March 05, 2014, 03:54:24 AM »
hi guys
need some help for installing heater in bus want basement model with ducts ?
scanzel
« Reply #1 on: March 05, 2014, 05:24:43 AM »
What fuel source, propane, diesel, electric ? Many options available depending on how you set it up and what your budget is. ProHeat X45, Webasto Hydronic or Airtop, AquaHot.
Steve Canzellarini
Berlin, CT
1989 Prevost XL
codretaw1
« Reply #2 on: March 06, 2014, 04:28:02 AM »
was thinking propane bus is 35 ft long x 7 ft less than 300 sq ft now I only have heat from engine up front
have plenty of space below for heater
hatchhome
Jesus loves you, everyone else thinks your NUTS!
My wife is looking for the bus nut cure.
« Reply #3 on: March 06, 2014, 06:17:02 AM »
I would look into ductless ac/heater units. They are on ebay and they have a outside unit that runs into a hotel looking unit. Make sure you get installed right and a good brand (eBay was just for reference) Its how I'm doing my rv/bus so I don't have any units or holes in my roof. Cheers
Cameron Hatch
New Orleans, LA
504-250-4838
« Reply #4 on: March 06, 2014, 08:59:23 AM »
Cheap way to go is propane RV type furnace. At 35,000btu, that's more then enough for heating. Suburban makes one that has a remote outside vent that is only 3 x 6" and can be chrome. Atwood makes a good one too, but it has a large outside door since it is mounted and serviced from the outside. If mounted in the baggage compartment, just have to make a box for the furnace so to get the air from inside-rather then heating the cold baggage air. My first Atwood furnace went 18 years-until I left it on for 2 weeks. I could have just replaced the fan motor, but Atwood had made a newer type fan that is quieter-hence I replaced it. You should be able to setup the entire system for under $1,000.00. Good Luck, TomC
codretaw1
« Reply #5 on: March 06, 2014, 02:07:51 PM »
thanks guys
