January 20, 2018, 04:56:43 PM *
Author Topic: Webasto Heater, Seperate Diesel Tank?  (Read 2084 times)
« on: December 10, 2006, 06:41:03 AM »
Good Morning All,
I have searched the threads on Webasto and found nothing relating to which tank to draw from.
What is recommended?
I have the main, and a 30 ga. one for the genset. Should I add another or use which one?
I have not purchased anything yet, just doing some more research.
« Reply #1 on: December 10, 2006, 06:47:01 AM »
No need to install another tank.  I would use the generator tank so you can use off road diesel to supply the Webasto and the generator.
« Reply #2 on: December 10, 2006, 07:05:09 AM »
Hi Paul,
Also try searching ProHeat, Thats what we just installed and piped it off the main tank.
I calculated it uses roughly 1 1/2 gal a day to keep my coach at 70 deg. in moderate weather. [35 40 deg.]
Not bad at all, I think. Barely notice it on the fuel guage...
Good Luck
« Reply #3 on: December 11, 2006, 12:23:20 PM »
I agree with Brian -- pipe the Webatso supply and return to the separate generator tank.  You can then use off-road (dyed) diesel in that tank, saving some money on your heating.
I would also install a small electric fuel pump and a manual, moentary switch to transfer fuel from the main engine tank to the generator/webasto tank.  This will allow you to get some fuel to your generator and/or Webasto in an emergency.
tekebird
« Reply #4 on: December 11, 2006, 03:54:19 PM »
due to the low fuel consuption do what is easier,
I would go off the main tank....as you will never run that dry.......plus it will not limit your gen usage
« Reply #5 on: December 11, 2006, 05:07:07 PM »
And this writer will suggest to use the generator tank so that you may keep your costs isolated:
fuel mileage for transport seperate from living generator/webasto expences.
You do what works for you!
« Reply #6 on: December 11, 2006, 06:44:15 PM »
As always, Thanks for your thoughts and preferances.
I am leaning toward using the gen tank now.
I like this idea.
Happy Trails,
