February 25, 2018, 02:01:27 AM *
Author Topic: Bus Machanic in Quartzsite Az  (Read 1261 times)
Danr
« on: April 10, 2014, 07:58:28 AM »
I does anybody no if there is a good mechanic in Quartzsite Az. Need to replace fuel line from tank to engine in a 1977 Mci.
not sure about what motor it has in it. either a 8V71 or 8V92 it was changed out a few years ago.
Will need to get Batteries for it. They took off the Radiator hoses for some reason.
That is about all I know right now just trying to find someone down there to fix it.
Is there a way to air it  up without starting it up need to move it.
Thanks for the help.
Danr
« Last Edit: April 10, 2014, 08:07:26 AM by Danr » Logged
ol713
« Reply #1 on: April 10, 2014, 08:26:12 AM »
 Hi;
   Don't know about a mechanic,  but there should be a port
   to air up the auxillary air system.  The port is located in the
   compartment under the drivers seat.  It is to air up the
   brake system, then the bus should be moveable.
                                    Good luck,    Merle.
« Reply #2 on: April 10, 2014, 09:10:04 AM »
Call Derrick @775-250-4131 he owns a MCI and a pretty good mechanic if he is not in Quartzsite he will probably be in Parker 20 miles away he will help you he was just south in the campgrounds but I forget which one look for a white MCI 8
Danr
« Reply #3 on: April 17, 2014, 07:13:26 PM »
Luvrbus do you know of any one else in Quartzsite Derrick is in Golden Valley now so Still need to find some one to help
But this bus back on the road. 1977 Mci with a 6V92 in it.
Danr
« Reply #4 on: April 17, 2014, 07:22:06 PM »
Not this time of the year they have all left I would help but I am 120 mile north of you
