April 23, 2018, 10:10:12 PM *
Author Topic: Wiper delay switch?  (Read 784 times)
goutoe
« on: May 24, 2014, 07:08:28 AM »
Have any of you guys added a wiper delay/ mist switch? my wipers are electric 2 speed on seperate switches, I have found a few on line, about 100 bucks ea. I would need 2 to do it right, or just one on the drivers side to get by, any ideas of a good brand to buy, or what not to buy? Thanks.>>>>> John.
John & Linda 1977 AM General 6V92 turbo Detroit 3 Speed allison, 40 ft.
« Reply #1 on: May 24, 2014, 07:20:42 AM »
I also have an AMGeneral. I converted my air wipers to two electric motor system. It is controlled by a single rotating switch that also keeps the motors synchronized. The switch includes adjustable delay, low speed, high speed, push to wash. I used this company:
http://www.amequipment.com/ Good Luck, TomC
« Reply #2 on: May 24, 2014, 08:24:28 AM »
I think there is a bit more info needed to help selevt a switch. Like voltage, one switch or two, and if the current motor(s) are permanent magnet etc.
Try looking here: I FIXED THE LINKS I THINK....SORRY
http://www.colehersee.com/home/item/cat/120/75600-04/
http://www.colehersee.com/home/grid/cat/121/
http://www.colehersee.com/assets/files/catalogs/1303152527-CLH-080MasterCatSectionE.pdf
« Last Edit: May 24, 2014, 02:14:26 PM by eagle19952 » Logged
Donald PH
