May 23, 2018, 12:31:31 AM *
Author Topic: Can I hook up trailer brakes?  (Read 1168 times)
Bryan
« on: June 18, 2014, 10:20:18 AM »
I've had 2 SUVs in which it was easy as plug and play to use trailer brake boxes. How would I go about hooking one up to the bus to activate trailer brakes when bus brakes are applied? Thanks for your help!
Bryan
1996 Prevost XL
1967 PD4107-756
Toccoa, GA
DriverGT5
« Reply #1 on: June 18, 2014, 10:50:43 AM »
I just went through a similar discussion last week. How are your brake lights on the bus activated right now?
From what I can tell with my setup I have a Bendix box that receives a pressure signal from the air brakes to activate the tail lights. Regardless how your setup is, there should be many power and ground supplies either up front or in the back. I elected to go with an inertia style brake controller system on mine for ease and cost.
To install you'll need to find a power and ground supply, a brake signal (tail light output) and then mount the unit up front where you can reach it. The fourth wire (blue usually) goes to the trailer connector and supplies a brake signal. If you have electronic brakes it will activate the magnets. Several people here are running that wire to an electric/hydraulic master that supplies fluid to hydraulic trailer brakes.
Alternatively you could go old school and run a hydraulic hitch. The more pressure the trailer applies to the hitch the more fluid pressure goes into the hydraulic brakes. No controller needed.
With air brakes you even could run a line to air cylinders on the trailer.
Regardless you probably won't find a plug and play connector like most trucks/suvs have. You'll have to run the wires yourself and crimp/solder them to the controller harness.
1968 Eagle Series 05 - 7616
8v71
www.tinyhouselife.com
DriverGT5
« Reply #2 on: June 18, 2014, 10:56:23 AM »
Do you already have a trailer wire harness installed for turn signals and brake lights? If so, how many pins is it?
8v71
chessie4905
« Reply #3 on: June 18, 2014, 04:26:48 PM »
   I assume your coach is 12volt. You have a brake light source under the driver's seat compartment. Bendix 2 1/2 round puck with two terminals that threads into the brake application line. Make sure you use the correct terminal.
GMC h8h 649#028 (4905)
Pennsylvania-central
Rick 74 MC-8
« Reply #4 on: June 18, 2014, 05:10:50 PM »
I just hook mine up last week I took a brake signal from my taillight converter since its 12 volts and my bus is 24. for the 12 Volt into thebrake controller and ran a lead back to operate the trailer I'm not sure the brand name of the my controller water that a big box store said it had progressive braking. it does very nice system would buy it again it was about a hundred bucks
Rick
Dave5Cs
« Reply #5 on: June 20, 2014, 08:46:07 PM »
Ready brake we have is a surge brake. bus stops so does it proportionally. 1 Cable around the brake peddle in the cab of my truck to the ready-brake that goes between the hitch and the tow bar. 1 wire to truck tail light circuit and turn sigs. 1 breakaway cable box and then to hitch, done.
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
