May 25, 2018, 10:02:09 AM *
Author Topic: Delco 50DN Alternator and MCI MC9  (Read 980 times)
wagwar
« on: June 26, 2014, 05:44:22 PM »
Does anyone know what/where the negative (ground) connection is on a Delco 50 DN on a DD 6V92T in an '81 MCI MC9? Is it grounded through the engine and frame? If so, is a ground strap advisable?
I'm installing a Sterling advanced regulator and it calls for connections to the alternator ground connection.
I've searched the web, but I have found the Field, Batt + and R1 connections on the 50DN, but no negative?
Thanks in advance.
« Reply #1 on: June 26, 2014, 05:48:06 PM »
Grounded through the chassis - it's bolted to ground, basically.  You can use any ground point that's handy on the engine.
« Reply #2 on: June 26, 2014, 06:09:43 PM »
The VR has a ground post but not the alt.
