June 20, 2018, 05:24:05 PM *
Author Topic: Drivers side low beam.  (Read 2379 times)
biff
« on: June 27, 2014, 07:11:16 PM »
Hi all. does anyone know way mci rotated the drivers side low beam 3 degres counterclockwise. its a77 mc8. only thing i can think of so the light would hit the car in front of you in his mirror.so he would speed up. Grin
biff
« Reply #1 on: July 06, 2014, 06:04:22 PM »
I can't believe no one has a answer. Undecided
« Last Edit: July 06, 2014, 06:08:20 PM by biff » Logged
« Reply #2 on: July 06, 2014, 06:50:17 PM »
Honestly, this is the first time I've ever heard of this, so I'm just as curious as you are. My suspicion is that nobody else has heard of it either.
biff
« Reply #3 on: July 06, 2014, 09:50:11 PM »
Well dose anyone else have the same thing on there bus.I can,t beleave im the only one. that has one. Roll Eyes
lvmci
« Reply #4 on: July 06, 2014, 11:17:59 PM »
I havent heard of it either, the lense has small (Fresnel) lenses moulded into the overall lense that are picked by the design engineers to spread the light in a specific way, spreading it out and concentrating it in other areas, so to speak. The bottle is designed to mount in a specific way, as far as Im aware,  lvmci...
MCI 102C3 8V92, Allison HT740
« Reply #5 on: July 07, 2014, 03:58:58 AM »
You probably have a 35 year old headlight bucket that has shifted three degrees counter clockwise over time.  It's about the last thing I would think about.  No, mine don't do that but then mine have been changed to square headlights.
Low Class
« Reply #6 on: July 07, 2014, 04:35:43 AM »
My curbside headlight assembly is rotated slightly clockwise.  It is clearly a case of poor workmanship.
Jim Keefauver/1985 Wanderlodge PT36/6V92TA/MT654CR/East Tn.
chessie4905
« Reply #7 on: July 07, 2014, 05:28:03 AM »
   Could the bucket be from the other side? Maybe left and right sides are slightly different. Bulb does match any other units and not an incorrectly assembled unit?
GMC h8h 649#028 (4905)
Pennsylvania-central
« Reply #8 on: July 07, 2014, 08:12:52 AM »
Possibly, but again, I don't know for sure if right and left sides are different. It seems like they are, because the adjuster screws are typically on the top and outside,
if I recall correctly.
Maybe it's installed upside down or something.
biff
« Reply #9 on: July 07, 2014, 08:23:50 AM »
The buckets are right and left. but the left one has the oriontation notches turned slitley 1/8 in. it is made to turn the sealed beam. but i don't know why! thanks for the responce. Grin
Utahclaimjumper
« Reply #10 on: July 07, 2014, 09:39:16 AM »
Don't you think a 37 year old bus has had a lot of changes/repairs over the years, it did not leave the factory that way as even back then correct headlight aiming was controlled by the feds.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #11 on: July 07, 2014, 09:48:56 AM »
Well guys I have a Trailways Eagle here that has the same notches on the left can he is talking about to rotate the beam I guess that what he is talking about but I have no idea why you would want to rotate a sealed beam unless you want more coverage on that side or it could have been for identification of some type ?
lvmci
« Reply #12 on: July 07, 2014, 12:21:10 PM »
Is there a glass nipple sticking out of the back of the sealed beam that matches the bucket notch? Could they have been something else than sealed beams? Lvmci...
« Last Edit: July 07, 2014, 12:23:29 PM by lvmci » Logged
biff
« Reply #13 on: July 07, 2014, 02:50:49 PM »
Yes all 4 lamps have 3 locators there a standard sealed beam. Im begining to think it was manufactured wrong. got pressed out of oreiontation. Undecided
