May 23, 2018, 02:23:48 AM *
Author Topic: tachometer drive ratio?  (Read 742 times)
« on: July 02, 2014, 12:15:58 PM »
My engine has a tachometer drive coming off the blower in some way.  It probably has a gear ratio driving it at other than blower speed, in order to make it useful.  Does anyone know if Detroit had a standard ratio for the tach drive to crank speed?  I was just going through some stuff and found a cable drive tach that I might try to hook up.  Picture has it showing with a little blue cap on it, just beside the blower drive cover plate.
Thanks, Brian
« Reply #1 on: July 02, 2014, 12:32:48 PM »
I think the drive is specific to the tach...I could be wrong I often am... Huh
Donald PH
« Reply #2 on: July 02, 2014, 07:05:56 PM »
That drive to the angle can be from 1.80 to 2.05:1 ratio are you your the tyne shaft is there most get broken off over the years and are never drilled out
« Last Edit: July 02, 2014, 07:31:36 PM by luvrbus » Logged
