January 21, 2018, 06:41:55 AM *
Author Topic: Brake air lines  (Read 3157 times)
« Reply #15 on: July 14, 2014, 06:38:15 PM »
  I thought we were talking about those rubber short hoses that connect to the brake chamber that are factory made with appropriate fittings, not made by some counter jockey with a roll of hose, fittings and a hose crimper. That would be insanely expensive.
This is what I thought too.  Even if I replaced every one of the rubber air hoses to the brake chambers with new factory made ones the total should be under $100.
« Reply #16 on: July 14, 2014, 06:46:55 PM »
   Here:
http://www.nickstruckparts.com/airhose.html
that site shows 10$ for a 3 ft x 1/2" hose.....that you can make for $1.50 with your old fitting...if a 3 foot hose will work for you...they never do in my experience.
to each his own.
Donald PH
