February 23, 2018, 12:54:50 AM *
Pages: [1] 2 3 4   Go Down
Author Topic: HELP - Need help troubleshooting rear end  (Read 9780 times)
Seangie
www.herdofturtles.org
« on: August 04, 2014, 01:24:17 PM »
Hey guys -  We are still stuck in Ronan MT.  I finally got to replacing the seals on the drive wheels on the bus.  We found that the rear passenger side seal was leaking and made a mess.  The bearings seemed fine though on both sides - No scarring or gouges, bearings in good shape.
Still trying to figure out what the noise is.
When we turn the axle on the passenger side of the bus (short axle) we are hearing a clacking (gear) noise in the differential and or dropbox.  We tried using a screwdriver to narrow down where it is coming from but cant quite put our finger on it.  It seems to be more prominent on the short axle side.
I have a video down the bottom that you can hear the noise we are hearing (around 8 seconds in) but here are my questions.
1. Is this clacking noise normal with both wheels off and the oil drained?  (We didnt hear or feel it on the drivers side until after we pulled the passenger side)
2.If the drop box needs to be repaired can the drop box be taken off without having to drip the whole rear end?
3. If this is a rear end issue can any truck repair place do the work?
4.  Are the parts for the dropbox and rear end availble or are they made from unobtainium?
5. What type of oil should I use in the rear end? (Synthetic preferred) and how much?
6.  Anyone know the part number for the gaskets on the axle caps?
Ive got a million things flying through my head right now and Im a little stressed Smiley
If you can number your answers to match the questions it would be helpful.
Im off to the parts place to get new seals.
Thanks guys.
'Cause you know we,
Driving through the night
To that old promised land'
Seangie
« Reply #1 on: August 04, 2014, 01:26:38 PM »
Here is the video...you might not be able to hear the noise unless your in a quiet room with decent speakers or headphones. http://youtu.be/FY9jxR1Z-D4
'Cause you know we,
« Reply #2 on: August 04, 2014, 01:42:46 PM »
the gaskets are easily made with gasket stock, (heavy)  and a ball peen hammer. i would not buy them.
2. Yes the drop box is removed without " having to drip the whole rear end..."
3. I would not trust "just any" shop...a transmission shop/ drive-line builder is from whom I would seek a reference....
5. Synthetic would not be my preference.....you'll get answers all over the map on this...use what Eagle suggests/recommends SAE 80W90 EP.
Someone will be along to correct me...I'm sure.
I think the drop box covers can be removed without removing the unit....to inspect it....
« Last Edit: August 04, 2014, 02:09:20 PM by eagle19952 » Logged
Donald PH
« Reply #3 on: August 04, 2014, 02:12:14 PM »
Sounds like the ring gear has come loose on the carrier being the ring gear is on the short side,you can remove the drop box without removing the differential, any truck place can repair the differential,you can rebuild the drop box your self bearing are all most ever need and any truck repair will have the gaskets for very little cash.
If the ring gear has broken or come loose and if you have the 3:73 go to a 3:36 ratio the little 6v92 will love you forever and they hold 19 qts of of grease cheaper to buy a 5 gal bucket
 Have you drained the grease to see how much metal is in the case ? that will tell you in hurry if something is going on that is where you start first then worry if it is full of metal Cool
« Last Edit: August 04, 2014, 02:19:38 PM by luvrbus » Logged
Seangie
« Reply #4 on: August 04, 2014, 02:18:42 PM »
Cliff - can we replace the ring gear without having to drop the rear end?
Thanks.
'Cause you know we,
« Reply #5 on: August 04, 2014, 02:24:18 PM »
The center comes out of the housing  to replace the ring gear if that is what you are asking ,pull both axles remove the circle of bolts and you have 2 places to screw bolts into to force the center ( or pumpkins some call the center) from the housing
« Reply #6 on: August 04, 2014, 02:40:15 PM »
I will guess side gear or spider pinion....
Donald PH
Pvoth
« Reply #7 on: August 04, 2014, 02:48:05 PM »
Is this where the proctologist line goes....sorry Undecided
« Reply #8 on: August 04, 2014, 03:32:12 PM »
Thanks.
the pumpkin comes out .... the axle housing stays .... the bus needs to be raised high enough to get a jack in and out  Grin
Donald PH
Lee Bradley
« Reply #9 on: August 04, 2014, 04:00:01 PM »
There are several shops south of you in Missoula, Mt
akroyaleagle
« Reply #10 on: August 04, 2014, 04:15:57 PM »
Pretty difficult to diagnose from the video.
I would get a flexible magnet and search around in the fill hole
and see if I could drag anything out.
The "clacking" noise may just be normal gear noise.
Were you having any problems bdfore replacing the wheel seal?
It's real easy to imagine the worst and start throwing money.
Let us know what you find.
Joe Laird
'78 Eagle
Sioux Falls, South Dakota
« Reply #11 on: August 04, 2014, 06:36:59 PM »
Sean, there is a good truck repair shop in Kalispell an hour or two North of you. They have helped me out once really well. And the people who bought my old bus as well when they blew the clutch out. I'll be back at my bus tomorrow and can send you their name and number if you need. Good luck.
Blackie AB
Seangie
« Reply #12 on: August 04, 2014, 08:57:29 PM »
Hey all -
Thanks again.  Its been a crazy day here.  Finally found some brake pads.  The shop I am at now is not comfortable pulling the pumpkin as we dont have the right jacks/lifts to do it.
We are both concerned about driving it an hour or two but tomorrow we are putting the seals and wheels back together and Im going to give it a drive around and see how it does.  I think I am a little more nervous than I ought to be.  Hopefully its all in my head.
JC - Please send that shop info.  Im calling around tomorrow to see if I can find a place.
PS - When we dropped the oil there were not any parts or pieces.   Just shavings on the plug.  Nothing to raise an eyebrow at.
Thanks guys.
'Cause you know we,
Lee Bradley
« Reply #13 on: August 04, 2014, 11:45:54 PM »
Sean,
Try http://www.inlandtruck.com/locations/missoula-mt.php
and its not to far from a craft brewer http://bigskybrew.com/
« Last Edit: August 04, 2014, 11:54:08 PM by Lee Bradley » Logged
tomhamrick
« Reply #14 on: August 05, 2014, 05:21:06 AM »
Hi Sean,
I would not be concerned about the drop box since I replaced the one on your bus with a new off the shelf from Jefferson. They are supposed to run 300,000 miles and the original had 500,000 on it. Also when the drop box was replaced the entire pumpkin was removed and taken to a shop that rebuilds them and inspected. He told me that it looked great and needed no repairs. Also cleaned the entire axle assembly just in case there where some drop box debris that got in there. Things can break but it should not be worn. Be interested to see what you find.
Tom Hamrick
1991 Prevost H3-40 VIP
1981 Eagle 10
Forest City, NC
Pages: [1] 2 3 4   Go Up
