May 25, 2018, 11:28:38 PM *
Author Topic: 1964 4106 Driver's side windshield wiper  (Read 2450 times)
Cosmo
"Waitin' for the Bus"
« on: August 10, 2014, 06:42:20 PM »
As I'm in the process of getting this bus together came across a problem. Looks like the bottom threaded piece of the driver's windshield wiper arm has been snapped off. The PO had placed a flat washer over it and welded it in place. Works in a pinch, but I want it right. So not knowing, can I replace that piece or do I need to replace the whole wiper motor? Either way I need to find a replacement. Anybody out there have a spare? I know this is helpful, it's air driven. Also would be willing to trade a complete set of splash aprons for an "06" if you're interested. Thanks!
"I have bus fever, kinda like Harley crotch"
1964 GM PD4106 - 2473
DD V8-71/ Spicer 4 speed/ Wind
« Reply #1 on: August 10, 2014, 06:46:44 PM »
If the wiper motor is air powered, this would be a good time to convert to a two motor electric. I did that and the two motors are synchonized electronically to each other so they stay in time. I really like the adjustable intermittant feature. Good Luck, TomC
Melbo
MC8 under construction
« Reply #2 on: August 10, 2014, 06:57:24 PM »
I have a one motor set up that I had to do some engineering on.  No I am not an engineer and I don't even pretend to be one on tv.  Came out of a semi truck and works great.
HTH
Melbo
Cosmo
« Reply #3 on: August 11, 2014, 05:54:46 PM »
Tom part numbers? Thought about doing that, but figured it would be as easy to replace.
« Reply #4 on: August 11, 2014, 08:56:41 PM »
Rick -
Easiest way to solve the problem is to call Luke in NJ: 1-888-262-2434
Or maybe Larry might pull the one off the coach you just snagged parts of.
These Sprague motors are extremely dependable, and usually only need a squirt of lube every fall to keep them operating at their peak.  They also work well in snow, where sometimes electrics will overheat.
If, as a future project, you wish to switch to electric, Autex is one brand that's commonly used.
Cosmo
« Reply #5 on: August 16, 2014, 04:17:47 PM »
As I am always learning, what I'm looking for is the bracket that has the idler arm attached to the bracket. Talked to Luke, there are a lot of brackets out there with minor changes but critical to get the right one. Asked me to send him my old one to match up. Also there is an outfit in west Kansas that has one or repair the one I have, again must ship the old one. I have options, so it's going to get repaired, Ed in OKC told me to bring down my old one and he should have a replacement.  Trim ring came in today and I chased the threads, thanks. Very nice, going to OKC this coming Friday to my chrome shop and drop them off. I'll get a bracket from Ed then since I will already be down there. Was looking to trade a splash apron for the bracket. It all worked out.
chessie4905
« Reply #6 on: August 16, 2014, 05:19:03 PM »
   If someone has a 4106 parts manual, run the bracket part number at Mohawk bus parts. Maybe it is still available. I don't know whether the 4905 is the same.
GMC h8h 649#028 (4905)
Pennsylvania-central
Cosmo
« Reply #7 on: August 16, 2014, 05:31:03 PM »
I keep telling myself to get a parts manual lol. I have the service manual, just put it in a binder today to keep in one piece.
wildbob24
« Reply #8 on: August 16, 2014, 07:57:23 PM »
Cosmo,
The part number for that bracket is 2422014. It is, of course, discontinued.
No luck at Mohawk's website.
Looks like a used one or repairing yours may be your only options.
Bob
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
Greenville, GA
chessie4905
« Reply #9 on: August 17, 2014, 09:21:28 AM »
   Same part number that is used on 4107, 4108, 4903,4905, h8h649.
Cosmo
« Reply #10 on: August 22, 2014, 08:23:03 PM »
I got the parts that I needed to repair my idler arm thanks for all the advice. Moving forward on the tail light front. Getting the trim rings chromed and found some NOS lens  from the Tail Light King out of Texas. Just need to clean up the rat nest of wires!
