May 22, 2018, 07:15:36 AM *
Author Topic: CruiseAir not getting cold  (Read 1482 times)
digesterman
« on: August 10, 2014, 08:41:56 PM »
One of my cruise air units gets cold then cycles, getting warm then back to cold, is this a sign it could be low on refrigerate ? Also on starting back out of the cycle it pulls a lot of amps for about 4 to 5 seconds. Any ideas?
Lee
Le Mirage XL 45E
Detroit Series 60
470HP
111,230 original miles (11-2015)
Mex-Busnut
« Reply #1 on: August 11, 2014, 04:22:13 AM »
Have you checked its air filter?
Jake brakes
digesterman
Re:
« Reply #2 on: August 11, 2014, 05:26:11 AM »
Darn, good point, afraid I overlooked the obvious. Will do today, thanks Mex Busnut.
Lee
Le Mirage XL 45E
Detroit Series 60
470HP
« Reply #3 on: August 11, 2014, 05:47:25 AM »
Those units are sensitive to build up on the condenser they need to be washed and cleaned every year it's the high pressure switch kicking it off and I doubt you find a filter in the system
Mex-Busnut
« Reply #4 on: August 11, 2014, 05:58:20 AM »
Here is the link to the air filters used on these units. Perhaps you can tell us your model number.
http://www.cruiseac.com/filter-spares.php
Jake brakes
« Reply #5 on: August 11, 2014, 06:15:59 AM »
Steve those are inline freon filters he needs a tech to change those,I never had air filters on my Cruiseair and they worked for 20 years IMO the best unit on the market if installed right
digesterman
Re:
« Reply #6 on: August 11, 2014, 06:27:36 AM »
Thanks for that info Clifford, my front unit I did check and it was clean, it works great, ice cold. The rear one is the problem. Is it okay to spray down with dawn soap then use pressure washer or best to stick with garden hose? Thanks
Lee
Le Mirage XL 45E
Detroit Series 60
470HP
Cary and Don
« Reply #7 on: August 11, 2014, 12:12:31 PM »
We called the Cruise Air people when ours had a problem.  They are more than happy to trouble shoot it with you. They are really helpful. We had an internal switch that had to be replaced and start condenser to replace. They even walked us through charging the freon to the right level.
Don and Cary
1973 05 Eagle
Neoplan AN340
