April 24, 2018, 12:17:52 AM *
Author Topic: Dreamscape air compressor need information  (Read 1485 times)
« on: December 22, 2006, 04:01:03 PM »
can any body tell me if a air compressor from a 8v92 will work on a 8v81 paul can not find a compressor and i have one from a 8v92 but do not know if it will fit please help
John E. Smith
« Reply #1 on: December 22, 2006, 08:48:34 PM »
The short answer is yes, in a pinch.
You may have to change the drive dog on the compressor, but the shaft is the same.  The only real variables are the compressor capacity and whether it is a truck compressor or an Eagle compressor.  Truck compressors have the discharge and intake ports on the opposite side -- you can re-work the air connections to accomodate that if you have to, though.
The drive dog is pretty easy to change -- one bolt on the end of the shaft.  Use a puller to pull it off of the shaft.  The mounting is the same on both, though.
John E. Smith
