January 17, 2018, 12:23:55 PM *
Author Topic: TPS Repair  (Read 1482 times)
« on: December 23, 2006, 02:03:45 PM »
I've narrowed my MD3060 problems down to a possible bad TPS.  The resistance readings are not what is expected and very narrow. The question:  Can the TPS be dis-assembled and cleaned with a solvent of some kind?  I'm thinking of electronic tuner cleaner or something. I haven't removed it yet and I can't see if it comes apart.  Any experience here?
Len
Torquester
« Reply #1 on: December 23, 2006, 03:29:11 PM »
Hi Len,
Maybe, if you can get it apart, electronic cleaner might work for a while. You will see, once you get inside, that it is just a simple rheostat. I would sugest that it has prolly lived its useful life.
hth, Tq
Torquester
1974 Silver Eagle, 3406 Caterpillar, South Dakota
« Reply #2 on: December 23, 2006, 03:34:08 PM »
My guess would be it started life a sealed unit, and is no more.
Even if you get it to sort of work, I doubt it will stay reliable.
Time to spend on a Cristmas present for yourself/the bus!!
Then it is done once, done permanently, and you may mess around with the other things on the "to do" list!
DuaneMC7
« Reply #3 on: December 23, 2006, 03:49:53 PM »
You have a little time left, ask Santa Grin
Remember, anything’s possible it’s just iron, well, almost.
« Reply #4 on: December 23, 2006, 07:53:28 PM »
Keep the old TPS so that you can "orient" the new unit to exactly the same position.   Yours may not be adjustable, but many are.   I agree with the opinion that a TPS isn't typically serviceable.  The shaft seals leak and once they start to fail, they are permanently screwed.
JR
« Reply #5 on: December 24, 2006, 10:51:38 AM »
Never mind, the TPS is OK!
There is something really wierd about this Cummins injector pump.  When it is running everything works well but when I operate the (air) throttle with the engine off, it doesn't return to idle by itself.  Just a little push on it at the engine brings it right back.  Think I'll add another return spring.
Anyway, thats why I thought my TPS resistance readings were off.
I'm convinced now that I have a software problem.  I can see that the ECU has been replaced and it most likely was not set up properly.  I'll try to get to Allison next week.
Len
