May 23, 2013, 08:54:50 PM *
Author Topic: Changing your Background  (Read 1676 times)
« on: April 05, 2006, 05:40:10 PM »
As you may have noticed, the board times are all listed as Pacific Standard Time. Three hours off for me in the Eastern Time zone.
To change this to your current time is very easy.
Go to the edit profile. I explained how to do this last night.
Under edit profile go to the Time Offset box and change the hours offset you need.
Since I am 3 hours earlier, I added +3 and then saved the profile.
Upon returning to the board wahala, all the times were correct for me. Those in Central would add +2 etc.
« Last Edit: December 25, 2006, 11:18:12 AM by DrivingMissLazy » Logged
plyonsMC9
Big Wheels Turnin'
« Reply #1 on: April 24, 2006, 03:18:49 PM »
For those of you wishing to change your background, the following will (I think) allow you to select one of the three now available. You may have to look around some for the buttons as they are in different locations on each Theme.
Starting out from scratch, open the board and find the home button. Click on it. Nothing really should happen.
Then find profile and click on it.
Then click on modify profile
Then find and click on Look and Layout Preferences
Edit profile screen should then come up and show your current Theme.
Click on Change.
Then select the theme you want to try.
Then click on use this theme.
That should be it. You should then go back to home and be in the new theme.
« Last Edit: December 25, 2006, 11:18:41 AM by DrivingMissLazy » Logged
Northern Arizona / 1983 - MC9
