May 27, 2018, 09:00:58 AM *
Author Topic: A/C and powersteering lines.  (Read 1848 times)
Slide
« on: January 02, 2007, 05:30:29 PM »
I'm getting ready to install dash air A/c and power steering in my 05 Eagle, I am planing to run steel lines the length of the bus with rubber hose at both ends. My question is, what side lines should I run ? I have in mind 3/8 for the high pressure and 1/2 for the return low pressure.Any and all input welcome,thanks.
« Reply #1 on: January 03, 2007, 04:35:49 PM »
Remember that the pressure line of the power steering can top out at 2500psi, even higher when cold.  Good Luck, TomC
