May 21, 2018, 04:23:44 AM *
Author Topic: Return trip from Arcadia & our 24vdc generator.  (Read 6029 times)
JerryH
« on: January 02, 2007, 05:56:25 PM »
Had an uneventful trip down to FL.  The Kohler genset worked without any issue as needed.  However, when we departed Lady Lake, FL on 1/1/07 ... about 15:min. into the trip I turned on the road A/C.  Shortly thereafter the A/C stopped and the "Not Generating" tell tale was lit.   Hmmm, I thought.  I thought possibly air, but instead found four of four belts powering the generator were trashed.
Well there we were on Rt-301, heading north on New Years day.  We passed autoparts store after autoparts store -- "Closed".  Found a Wal-Mart and "thought" they might have belts.  Nope!  Never looked before, but was hoping.  Was directed to a place up the street.
Ok, so I had "Da Book" (parts and maint.), but unless I missed something, there's no mention of the necessary belts or part number.  Next problem, find an autoparts store with 4 identical belts on hand.  We couldn't.  Unsure of the exact size, we did find something "close", but they only had 2.  Walked to another nearby autoparts store and they had 2 more.  Ahh problem.  Same number, difference makers and after hitting the air valve to tension the belts, 2 weren't the same tightness as the other 2.  That's not gonna work.  So we leave the 2 tight belts on the #2 and #4 pulley positions and head north -- all is good.  I try the A/C again.  Bad Idea.  No problem running 2 belts with NO A/C.  But once the load of the A/C is introduced, it toasted the 2 belts we had.  I struck out on finding any matching belts, which was fine as we really didn't have (or know) the "ideal" size for the application.
Ran 2 belts all the way home to PA without using the A/C.  Once the sunset in the FL/GA area, it was fine.  Didn't need it the next day (1/2/07).  Thanks to those who I phoned, picking your brains.
So does anyone know the factory specified belts for the 24vdc generator off an DD8V71??  Four belts in all.  You know, I had spare belts for the Kohler genset and the main fan (squirrel cage) ... but nothing else.  TAKE additional belts!
Jerry H.
« Last Edit: January 03, 2007, 04:37:26 AM by JerryH » Logged
« Reply #1 on: January 02, 2007, 07:23:01 PM »
Jerry,
We are glad you, Linda and the kids made it home OK!
Funny how, only the things that you never think will break..BREAK...
« Reply #2 on: January 03, 2007, 01:32:37 PM »
Hello.
Good strategy to reduce the electrical load.
Also a great situation in which the redundancy of a good inverter/charger powered by the genset could double as your alternator.
For the occasional mileage busnut, which most of us are, I might suggest a good preventive maintenance practice would be to change out the belts every couple of years, putting the new ones on the coach, and putting the old ones underneath as spares.
Might be good to wrap some masking tape around them and scribe a date of some sort..... memory not what it once was, too much other more important stuff in there, I guess!!!!
This is common practice in both road and marine environments. The airplane folks do the same, but, for some reason, have little need for the spares......
Fast Fred has preached the virtues of this practice longer than I.
MCI sells the belts in matched sets. Call their 800 number and get a set sent to you.
Canada 1-800-665-0155
US 1-800-323-1238
Technical Support 1-800-241-2947
Online parts store at http://www.mcicoach.com/Parts-Service-Support/partsServiceSupport.htm
JerryH
« Reply #3 on: January 03, 2007, 01:44:35 PM »
Hey, for what it's worth ... I phoned MCI who were quite helpful and got me the part number #8R-27-3, $10.45 ea.  Gotta get $100+ for free shipping or pay $30.00, $55.00 if over nited.
The MCI part number did cross reference at NAPA, in at $13.43 ea. and within 3-miles of my home.
But for sure ... check those belts.  While nosing around in doing the belt change, I also found some bundled wires (4 in all) which no longer had the appropriate wrap around the four of them.  So that'll be addressed when I swap the four belts tomorrow -- once the new belts arrive.
A side note, our main road air/heat blower is isolated (power-wise) to the 24vdc and I have no way to run it off our genset.  We could have run the house AC's off the genset if it got "really" bad ... but it didn't get to that point.
Jerry H.
pete81eaglefanasty
« Reply #4 on: January 03, 2007, 01:57:45 PM »
Jerry, for what it's worth I have learned from past experience that if you buy a match set of belts, they all have to be put on in the same direction.   You can tell the direction by keeping the numbers facing the same way, the embossed numbers not the painted numbers.A belt stretches different if put on the wrong direction, if two are put on one way and one the wrong way, you will notice the difference between the three, two will have more tension than the other one.
I have been a mechanic on the railroad and for other companies and have worked on many machines and if you don't put the belts on right you will notice the slack in the one that's wrong.  I know I will get some controversy over this, but it's the truth.   I hope this helps.
        Pete and Jean
          Fantasy
WHAT EVER YOU DO, OR TO WHO YOU DO IT TOO, DO IT WITH A SMILE, IT MAKES IT LEGAL THAT WAY.
« Reply #5 on: January 03, 2007, 02:09:40 PM »
Hello Jerry.
You can install a switch controlled jumper in the side instrument panel to enable the coach and AC blowers.
This bypasses the "no gen" relay. Only weakness is that you may accidently run the battery flat while the coach is sitting by engagaing the blowers with the engine off.
Mine was set-up with a big Webasto inline to the HVAC and the jumper. With a source of 24DC by way of a charger, you get stock style heat without the engine running.
Or, the ability to run the blowers if the alternator system fails and the genset and charger is brought into play.
The coach is 2 hours away, otherwise, I'd go check to see what it is attached to.
ol713
« Reply #6 on: January 05, 2007, 03:17:29 PM »
Hi;
     Hope it's not too late for you to check back on your post,   but
     here goes.  The belts are called out on pg.8-6 of your parts
     manual.  Part number is  8f-27-3.   (MC7 manual).   the parts
     and all should be the same.  I believe you have a MC-8.
     I had a similar experance.  passing thru Oakland, Ca  I lost the
     generator belts also.  To make a long story short,  I ended up
     using Gates belts,  # XL 7410  from a local auto parts store.
     That was approx 6yrs ago and I am going to replace them
     soon.  They are starting to slip.  I ahave another set of Gates
     belts available when I get time to change them.
                                   Good luck,   Merle
captain ron
« Reply #7 on: January 05, 2007, 04:24:21 PM »
Which MCI 8 setups had belts for the alternator/generator? Mine has the gear driven one like my old 8v71. The only belt mine has now that the ac compressor is out is the belt for the squirl cage blower for radiators
JerryH
« Reply #8 on: January 05, 2007, 05:54:17 PM »
I did in fact get the belts.
I called MCI Parts who were very helpful.  They gave me the part #8R-27-3.
The MCI price was $10.45 each.  But needed a $100.00 minimum for free S&H or pay $30- for 3 day service, $50+ for next day.
I opted for NAPA which got me the belts the next day.  The MCI did cross reference on their system to #XL-7420 @ $13.43 each.
So I went with $56.94 vs. the $90+
Merle:
Nope, never to late to add to a post -- always valuable information to be learned.
CptRon:
Ours is a '74 MCI with a DD8V71 and a HT-70 transmission (yes, HT-70 ... not 740).
Four belt pulley off the back, accessible from the drivers side rear access door.  Has air tensioner ... pretty easy to make the swap.
Thanks all,
Jerry H.
« Reply #9 on: January 05, 2007, 06:09:52 PM »
Hello.
My 1975 MC8 has belt drive, air cooled alternator.
The switch to gear drive, oil cooled came in somewhere shortly after, and shortly before the end of the MC8 run.
Some have retrofitted their earlier coaches, some have left it stock.
Save your 4 place pully for another busnut if you do the conversion, both the engine and the alternator ones.
They aren't getting any more plentiful.
JerryH
« Reply #10 on: January 14, 2007, 07:08:57 PM »
Re-vistiing this question ...
Ok, so here's a question for someone who might know.
The air-tensioner on the 4-belt 24vdc alternator -- there's the quarter turn air valve (same as on the large belted squirrel cage).
There's air feed in, and two out.  One leads to (if I remember) the top of the cylinder, the other leads into (what?) -- a diaphram of some sort?  From it, one line leads to the other end of the cylinder, while the other goes to a relay it appears.
My guess at this point is that (if it is some sort of diaphram) it's stuck, not allowing the air to make it to the cylinder.
So, anyones thought??
Jerry H.
« Reply #11 on: January 14, 2007, 07:59:37 PM »
Hello Jerry.
The belt tensioner is powered both ways: Keeps the belts tight in one position, and pulls the alternator up to allow you to more easily change/replace the belts. That's the lines to both ends of the cylinder, just like a hydraulic ram.
The system is also tied in with a pressure switch to a dash warning light, maybe the no gen light? or maybe low air? Can't remember.  No pressure for belt tension, you get warning light up front, I can't remember what is actually going on with the controls in that Penn switch attached to the rear junction box as to the functioning, just remember what happens, sort of!
JerryH
« Reply #12 on: January 15, 2007, 04:05:20 AM »
Hello Jerry.
Buswarrior:
Yeah, the one switch should be "Low Air" ... the "Not Gen" should (I believe) handled not from air, but from electrical output from the alternator.  I am referring to the one device after the one air line off the air valve.  Curious as to it's function.
Jerry H.
Stan
« Reply #13 on: January 15, 2007, 06:03:17 AM »
Is the device you are asking about not a pressure regulator to control the amount of tension on the belts?
« Reply #14 on: January 15, 2007, 08:38:40 AM »
From the foggy recesses of my brain this AM...and a schematic...
No air pressure on the belts, the system won't allow the alternator to be loaded, and the low air light will be on.
Somewhat goof proof, eh?
On my '75 MC8, the "Gen Control and Low Air switch" is plumbed into the loop to the alternator belt tensioner.
So, this is where the air pressure is sampled for the low air warning, as well as allowing the alternator to come online once sufficient belt tension (air pressure) is achieved to prevent throwing them off or slipping under load.
Good engineering? Two birds, one stone.
