March 20, 2018, 06:45:58 AM *
Question: Knowing what you know, which of these options would you now choose?
(2) Penguin 13.5K Heat Pumps - 0 (0%)
(1) Carrier AirV 13.5 Lo-Profile Heat Pump + (1) AirV 15K Heat Pump - 2 (66.7%)
Other - 1 (33.3%)
Total Voters: 3
Author Topic: VOTE! Carbunkle choices for MC9  (Read 1119 times)
« on: January 10, 2007, 08:49:05 AM »
Open floor plan, +- 30' of open space.
95% southwest travel. If I spend anytime in freezing temps, I'm doing something wrong! Smiley
Current understandings:
 - Dometic's warranty is better, 3yr vs. 2yr.
 - Dometics have three speed fans
 - Carrier's large unit has better CFM than Penguins - (365 vs 335...important?)
 - Carrier's amp draw is an amp or so less, even the large unit compared to the Penguins
 - Blower off when compressor off?
 - EMS connectivity / external compressor control possible?
 - Remote thermostat possible?
Getting this info from the web has been quite a frustration, and the couple of dealers I've talked to weren't any help.
After looking at the schematics, it appears that it's more straightforward to connect external controls to the Dometics, but I don't have any definitive proof of that.
What I'd like to do is use the manual units, then add external controls later when I get fancy.
Does anyone have any better information than the web sites of both Dometic and Carrier?
Many thanks!
