May 21, 2013, 10:46:41 PM *
Author Topic: 4905 Engine Pull Question  (Read 1087 times)
Rick Brown
« on: April 25, 2006, 06:37:47 PM »
I'm in the process of pulling the 8v71 out of my 4905.  The book says "Loosen dust cap from transmission propeller shaft slip joint".
When I look into the goo I don't see any obvious dust cap.  At what point does the transmission separate from the axle?  Does one u-joint go with the trans & the other stay with the axle or does the yoke pull out of the transmission?
Thanks for any input.
-Rick Brown in Reno, NV
Geoff
« Reply #1 on: April 25, 2006, 07:38:18 PM »
Right where the driveline separates (slip joint) there is a cap with a seal that screws into the larger half of the driveline.  Rather than letting the driveline separate you could take the driveline entirely off at each u-joint, this would make putting it back on easier.
--Geoff
Geoff
'82 RTS AZ
