April 24, 2018, 09:51:57 AM *
Pages: 1 2 3 [4]   Go Down
Author Topic: 8V92 Oil  (Read 26429 times)
« Reply #45 on: September 13, 2013, 11:13:37 AM »
In case you have a 149 series in your bus, 50 weight is also recommended (LOL). Good Luck, TomC
wg4t50
« Reply #46 on: September 13, 2013, 12:17:01 PM »
TomC,
You got it, I stayed clear of the 149 & 278A series, but had to get into the 110 series in case  you need any timing pins for a 110 ?.
Think can still find a few.
The reason for the 50 is better proven luck on the 8V-92 rear main, the 6V does not seem to have the issue.
As for the AT&T operation, my guess it was with the 12V-71 or 16V-71 as the71 series does not have the rear main issue like the 92, the part is a generator has a different duty cycle than a highway engine, like never being loaded under 1800 rpm etc, etc. when oil pressure is lower, off idle WOT.
Just another experienced view.
« Last Edit: September 13, 2013, 12:38:16 PM by wg4t50 » Logged
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
DaveNCari
« Reply #47 on: September 13, 2013, 12:53:19 PM »
Any Oreillys can order Delo 100 in straight 40.....that's where I get mine.
DG
Coming soon.....need of a bus-friendly RV park.....that values Liberty!
Watch this space....
« Reply #48 on: September 13, 2013, 07:41:15 PM »
Any O'Reillys can order Delo 100 in straight 40.....that's where I get mine.
Part Number:  100-40-1 CHV  (CHV goes in vendor box, if counterman's stumped.)
uncle ned
« Reply #49 on: September 14, 2013, 07:01:06 PM »
Worked around the 12v71 generators at our hospitals.  they were tested once a week. 0 to 18oo rpm in a instance. if not special detroit men were sent to check.
Not a room to be in pulling telephone wire through during a lightning storm.
instance hearing problem.
uncle ned
4104's forever
6v92 v730
Huggy Bear
Pages: 1 2 3 [4]   Go Up
