February 23, 2018, 06:36:40 PM *
Pages: 1 [2] 3 4   Go Down
Author Topic: Dump valve  (Read 2364 times)
NEWELL in South Carolina
« Reply #15 on: October 19, 2017, 07:15:55 PM »
http://www.adventurerv.net/waste-valve-wmetal-handles-p-9594.html
Or look for something like  --  Valterra T1029-2 RV Sewer Waste Valve Termination Adapter 3" Bayonet x 3" Hub
« Last Edit: October 19, 2017, 07:30:16 PM by kyle4501 » Logged
chessie4905
« Reply #16 on: October 20, 2017, 04:06:40 AM »
Is that an aluminum tank?
GMC h8h 649#028 (4905)
Pennsylvania-central
sledhead
« Reply #17 on: October 20, 2017, 05:14:58 AM »
because you have only 1 waste tank you could use a laundry pump 2 " in and 2 " out and pump it any were to the dump tank
I use this setup and I can drain my black tank 58 gal. and grey tank 125 gal  very fast and up hill if needed . I use a fire hose style hose that rolls up when finished . my toilet is a head hunter that blasts water right in the toilet drain pipe so there is no large stuff going into the tank
looks like I need another place to resize my pictures then this crap from photobullcrapbucket
and if need be I can remove the system and use the old 3 "slinky if I really really have to
dave
« Last Edit: October 20, 2017, 03:14:01 PM by sledhead » Logged
dave , karen
« Reply #18 on: October 20, 2017, 09:39:13 AM »
dave
pump make and model. source ?
Donald PH
richard5933
« Reply #19 on: October 20, 2017, 02:23:29 PM »
No. It's an early version of a polypropylene tank. Matching set - fresh and black are same size. Seem to be in good condition so I'm inclined to leave them alone for now.
I did find an adapter at a local RV store today. It goes from 3" pvc to a standard bayonet mount. Now I've just got to find a reduction bushing to glue into it to reduce the opening to the 2" MPT that's one the cast iron. Let's hope this works.
1964 GM PD4106-2412
KD9GRB
sledhead
« Reply #20 on: October 20, 2017, 03:21:35 PM »
pump is like this but mine has a 2 " in and 2 " out outlet
http://www.homedepot.com/p/AquaPro-1-3-HP-Utility-Sink-Pump-55011-7/206852252
works great
sorry about the pictures and photo crap
dave
dave , karen
richard5933
« Reply #21 on: October 20, 2017, 05:07:03 PM »
I picked up a glue-on bayonet fitting today. It's designed to go on 3" pipe. Also bought a reducing bushing and some appropriated sized PVC fittings, all in the hopes of replacing the downward-facing 2" cast iron nipple with the PVC & bayonet fitting. If all goes well, then it shouldn't hang down any lower than current setup. It seems that since I'm using PVC/ABS for the bottom portion, worst case scenario it becomes the weak link and snaps off if it hits something. It seems better to have the break below the floor in the plastic pieces rather than the cast iron parts above. The actual dump valve is so far inboard that I'm not worried about it.
I'll post photos once it's together.
1964 GM PD4106-2412
KD9GRB
« Reply #22 on: October 20, 2017, 08:50:54 PM »
works great
dave
Thank-you, all i could find for laundry pumps were submersibles Smiley
Donald PH
chessie4905
« Reply #23 on: October 21, 2017, 04:07:59 AM »
There were several posts a couple years ago about using a garbage disposal connected to a garden hose to empty holding tank. Was reported to work quite well and disposals just happen to have 3 inch inlets which easily facilitates connection to dump valve with short hose and adapter. I saw that one of the RV supply companies make something similar at much higher price point.
richard5933
« Reply #24 on: October 21, 2017, 01:19:09 PM »
Was easier than I thought
1974 GMC P8M4108A-125 (Current bus)
1964 GM PD4106-2412 (totalled Sept 2017)
KD9GRB
1964 GM PD4106-2412
KD9GRB
« Reply #25 on: October 21, 2017, 05:32:19 PM »
You are 'The MAN!'
Great solution!
richard5933
« Reply #26 on: October 21, 2017, 07:22:03 PM »
Another interesting thing I noticed...
The electrically operated pneumatic dump valve works amazingly well. Also had better than expected flow from just a 2" pipe. There was about 6 inches of blue water in the black tank (looks like someone really overdid the chemicals and tried to 'clean' the tank) and it flowed out before we knew it. I'm hoping that if we keep enough liquid in the tank the solids should flow out pretty well. In case they don't, I'm replacing the clean-out plug in the "T" fitting (see photo in earlier post) with an adapter & backflow preventer so that I can hook up a garden hose to flush out the dump valve and cast pipe without having to open anything up.
1964 GM PD4106-2412
KD9GRB
« Reply #27 on: October 21, 2017, 11:08:42 PM »
Richard -
As you said, not as difficult as you thought it would be.
You might want to consider substituting one of these for that orange connection to the coach adapter:
https://www.amazon.com/Valterra-T1026-1-45%C2%B0-Clearview-Adapter/dp/B000NCS7GE
I've found it works much better to slide my "slunky" under to get a nice smooth flow to the dump receptacle:
https://www.amazon.com/Level-Trek-LT80070-Sewer-Hose-Support/dp/B008OJ5H9I/ref=sr_1_5?s=automotive&ie=UTF8&qid=1508652109&sr=1-5&keywords=rv+sewer+hose+support
Then one of these at the end of the hose into the receptacle:
https://www.amazon.com/Camco-39736-RhinoFLEX-Bayonet-Fitting/dp/B01N5H2FCE/ref=sr_1_1?s=automotive&ie=UTF8&qid=1508652410&sr=1-1&keywords=camco+clear+sewer+elbow
richard5933
« Reply #28 on: October 22, 2017, 03:30:19 AM »
RJ - I had thought about that but hadn't had a chance to look on Amazon yet. It would certainly make a straighter run for the hose. I've already got the 90-deg bend on the far end. Thanks for the link.
1964 GM PD4106-2412
KD9GRB
chessie4905
« Reply #29 on: October 22, 2017, 07:09:28 AM »
I don't know how far that sticks down below body, but it looks like an accident waiting to happen some day. Like going over humped road or railroad tracks or going in or out of uneven ground at a rally. Other than that, good work around. I prefer drain outlet at bottom inside of compartment with a horizontal outlet.
Pages: 1 [2] 3 4   Go Up
