June 20, 2018, 08:41:50 AM *
Author Topic: How many btu's to heat my bus?  (Read 4232 times)
Tim Strommen
Electronics Geek
« Reply #15 on: February 01, 2007, 01:50:17 PM »
I posted this spreadsheet on the BNO BBS about a year ago - it was a re-vamp of a previous work I did the year before.
This spreadsheet is intended to determine the ammount of heatloading (for heating and cooling).  Graciously hosted (continually) by Jim Behr at: This Adress (self extracting zip file).
You'll need a copy of MS Excel, or the free Microsoft Excel Viewer at: This Adress
Cheers!
-Tim
Fremont, CA
1984 Gillig Phantom 40/102
Gary '79 5C
« Reply #16 on: February 01, 2007, 02:06:05 PM »
Thanks Tom on the kerosene heater suggestion as I know where one is stashed in a garage.
Question, as we keep our coach and lower bays warm, how is every one keeping their old DD warm?? I run the Webasto hydronic heat thru the block & coach. I am also afraid of a coolant heater hose giving out and loosing the coolant to the engine. I have not sprung the $ 500+ for the SS heater exchanger from Wrico. That would keep the two systems heated, but separate. Over nite I usually do not run the gen set. I have not plugged in the block heater to the inverter. let's see, (4) 8D batts with a 2000 watt inverter w/ 80% eff., 5 Amp draw at 120 volt on the block heater. The last is an estimate.. I do not think I have enough to operate the blk htr overnite.
Ocean City, NJ
« Reply #17 on: February 01, 2007, 02:35:11 PM »
Hi Gary,
How about a ProHeat and a flat plate heat exchanger to make a loop on the DD. Maybe you can figure
out a way to do it without bothering your existing heater hoses. Like, tap onto theheat pipes running in the tunnel?
The Flat Plate's can be found very cheap on e-bay.  100 to 150 dollars. We are using them for instant hot water.
