December 14, 2017, 11:04:56 AM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Coolant testing procedure help  (Read 1696 times)
Scott & Heather
MCI-9 & MCI-102
« Reply #30 on: November 02, 2017, 11:02:16 AM »
Arg. Still running hot.
Going to have to pull the radiators and inspect and if they are clean, water pump is next.
Sent from my iPhone using Tapatalk Pro
Scott & Heather
« Reply #31 on: November 02, 2017, 11:39:28 AM »
might as well tank the radiators...
Donald PH
Wants Paint Smiley
« Reply #32 on: November 02, 2017, 11:57:17 AM »
    What is the change interval for the antifreeze change, please?   Thanks,  BH
All depends on the brand and how it is monitored anywhere from 1 to 7 years DD wants it changed every 2 years regardless,Cummins wants the antifreeze tested once a year and replace when the the test is - which is about every 2 to 3 years
« Last Edit: November 02, 2017, 12:05:50 PM by luvrbus » Logged
Scott & Heather
MCI-9 & MCI-102
« Reply #33 on: November 02, 2017, 03:15:48 PM »
Ok, so if indeed I need to clean out these rads, what's the best method? Pull them, fill will vinegar, let sit for a day, then rinse?
Scott & Heather
« Reply #34 on: November 02, 2017, 04:39:38 PM »
Detroit used to have a 2 part cleaner.
You used the acid mixture first, then the neutralizer to rinse, you drain all of it into a drum, and at the end it is all neutralized mixed together.
Each powder comes in a gallon plastic jug. Use hot water to mix the powder, dissolves better.
And, HUGE PPE warning! Mono goggles please, you don't want this stuff splashed into your eyes!!!
Scott & Heather
MCI-9 & MCI-102
« Reply #35 on: November 02, 2017, 04:43:38 PM »
Thanks! Now to find this stuff...
Scott & Heather
chessie4905
« Reply #36 on: November 02, 2017, 05:53:38 PM »
Be careful if you have marginal radiators.
Here's one:    https://www.cumminsfiltration.com/south-pacific/cooling-system-cleaners
« Last Edit: November 02, 2017, 05:57:52 PM by chessie4905 » Logged
GMC h8h 649#028 (4905)
Pennsylvania-central
Scott & Heather
MCI-9 & MCI-102
« Reply #37 on: November 02, 2017, 07:31:39 PM »
Thanks for that link! I'll be getting some of this stuff. The radiators are in really really good shape from the outside. I had bad radiators on my old MCI 9 and replaced them with new ones so I know the visual differences. The inside may be a different story.
Scott & Heather
Pages: 1 2 [3]  All   Go Up
