December 14, 2017, 08:49:02 PM *
Author Topic: AD2 air dryer  (Read 1067 times)
« Reply #15 on: November 17, 2017, 10:06:14 AM »
I had an AD-2 on my first truck and was easy to rebuild. I now have an AD-9 and it was old enough where the rebuild kit didn't match up. That's why I just replaced the whole thing. Good Luck, TomC
Yea parts people get the AD-4 and the 9 all mixed up sometimes while both look the same they are not BTDT
brmax
« Reply #16 on: November 17, 2017, 10:41:47 AM »
Thats a good mention Tom, as there has been some upgrades on the purge valves.
Many times I found the need to remove the lines so cleaning the base with air and some brake and “electric” solvent most always, no make that always. This stuff was not harmful to rubber, I think Napa no longer makes the same product as before.
Them spin on dryers! I was lucky, had 3 before retiring, sweet. Just behind the cab on some dumps I maintained, just walk right up, no crawlin no pretzel bending. A real gem I thought with the few years experience with them.
Good Friday
Floyd
1992 MC9
6V92
Allison
« Reply #17 on: November 18, 2017, 07:47:19 AM »
"No crawlin no pretzel bending." The exact reason for switching to a truck conversion. Good Luck, TomC
Oonrahnjay
« Reply #18 on: November 24, 2017, 06:56:07 AM »
  Another option is to upgrade to an AD-IP or some other spin on replaceable cartridge style/make dryer. Bendix is not the only player in the market.
Then the desiccant can be service in <10 minutes.
     I did (but "some other" in that I went with the Bendix AD-IS}, but then again, I was working with a situation where there was never any air dryer on my bus and I was starting from scratch and the issue of existing brackets, fittings, valve lines, etc. didn't come up.  Also, I was replacing just about everything on the air system on my bus so I just designed a system (with the help of Bendix tech info and advice from the instructor at Bendix brake school) to take advantage of the isolated pressure ports on the AD-IS.  It doesn't make any difference Melbo and his needs, but there it is.
