December 14, 2017, 01:04:46 PM *
Pages: [1] 2 3 4   Go Down
Author Topic: Thatís one dirty toad!  (Read 2073 times)
Scott & Heather
MCI-9 & MCI-102
« on: November 27, 2017, 06:05:44 PM »
I should probably get all my 8v92 oil leaks fixed eventually, I mean when your toad leaves drip marks on the pavement when you park....took me an hour and two cans of engine degreaser to clean out the trucks intercooler fins and radiator fins from all the oil residue.
Sent from my iPhone using Tapatalk Pro
Scott & Heather
« Reply #1 on: November 27, 2017, 06:31:39 PM »
You need to fix your leaks.
Blackie AB
HB of CJ
« Reply #2 on: November 27, 2017, 06:44:17 PM »
Abenormal.
Gary Hatt - Publisher BCM
Publisher - BCM
Help Team
« Reply #3 on: November 27, 2017, 07:01:35 PM »
Not to worry.  I was told several years ago when I lived in the Northeast that every drop of oil (and tranny fluid) you take out of your car should be put back in the body and rocker panels to prevent them from rusting. I religiously took my vehicles to the undercoating guy every fall to have him spray used oil all underneath my car and I swear it helped.  So if you have a bit of an engine/tranny oil leak, take advantage of it and let is splash on your car and you will see how much longer your car lasts.  Not only that but all of your bolts and screws will come out much easier the next time you need to repair something.   Cheesy
Check it out here. https://www.youtube.com/watch?v=kaEaNsJXIUY
1967 Eagle with Series 60 Power Plant
Gary@BusConversions.com
sledhead
« Reply #4 on: November 28, 2017, 04:51:29 AM »
we oil spray all of our vehicles every year    BUT    use the right NEW oil  spray stuff . it is a pain in the a$$ but makes a huge difference . they like to use salt and now liquid brine on the roads     yuk !!
the leaks can be fixed . 1st year out with the wrong oil in the 6v92ta 15 w 40 truck oil ( dumb truck mechanic ) used that on everything . we oilsprayed the nissan so bad it took 4 times with windex just to clean the windows . but after full out of frame rebuild and the right oil 40 w  " voila " no more oil leaks
kind of like the light at the end of the tunnel
dave
dave , karen
Scott & Heather
MCI-9 & MCI-102
« Reply #5 on: November 28, 2017, 05:42:51 AM »
Lol. Dave I use straight 50 in the summer. I still have a wet toad. I detailed my engine compartment earlier this summer and realized every hose, gasket, and joint is leaking oil. Ugh
Scott & Heather
Dreadnought
"HMS Dreadnought"- 1964 MCI MC5
Live Fast, Live Well, Live Free!
« Reply #6 on: November 28, 2017, 06:07:16 AM »
What happened to the Toyota?
I'm guessing it didn't rust away lol
1964 MCI MC5 8v71
B_K
« Reply #7 on: November 28, 2017, 06:58:06 AM »
No it "slipped away"   Roll Eyes
« Reply #8 on: November 28, 2017, 07:26:34 AM »
He traded it in to a slimy salesman  Wink
Blackie AB
Geoff
« Reply #9 on: November 28, 2017, 08:28:03 AM »
I couldn't live with oil leaks like that, that is over the top.  And all the oil the toad misses, the cars behind collect.
Geoff
'82 RTS AZ
oltrunt
A fine BCM outting
« Reply #10 on: November 28, 2017, 09:21:58 AM »
So how long did you have to tow the salesman before he became slimy? Grin
Dreadnought
« Reply #11 on: November 28, 2017, 09:50:36 AM »
That's one slimy toad
1964 MCI MC5 8v71
pabusnut
« Reply #12 on: November 28, 2017, 10:07:12 AM »
That's why you always buy a toad that is a cross between the color of road dirt and dirty 40wt! Wink Cheesy
Steve
Steve Toomey
PAbusnut
muldoonman
1991 Prevost 8V92TA
« Reply #13 on: November 28, 2017, 05:03:13 PM »
Scott, is oil blowing out of the dreaded check valve tubes?
Hi yo silver
« Reply #14 on: November 28, 2017, 05:45:39 PM »
Where are you keeping the oil level on the dipstick? My DD 71 didn't like to be filled above the halfway point between low and full.
Pages: [1] 2 3 4   Go Up
