December 14, 2017, 08:50:17 PM *
Author Topic: starter  (Read 371 times)
richardmc9
« on: December 04, 2017, 05:41:18 PM »
Been a while but I need to know if a starter off a 8v71 t-drive fit a 871 v drive  v drive is in a 1980 gmc   T drive is in a Eagle
« Reply #1 on: December 04, 2017, 05:47:28 PM »
Nope the V drive uses a left hand starter
richardmc9
« Reply #2 on: December 04, 2017, 06:39:01 PM »
Thanks that 's  what I thought and I have three right hand starters two on 8v71 and one on a 6v92  I wonder who might have a left hand starter ?
« Reply #3 on: December 04, 2017, 06:48:34 PM »
You need a 12 or 24v ?
chessie4905
« Reply #4 on: December 05, 2017, 04:50:19 AM »
80 GMC has to be 24 volt. Cliff, do you know if the newer lighter gear reduction starter is available for the GMCs? Thanks.
GMC h8h 649#028 (4905)
Pennsylvania-central
« Reply #5 on: December 05, 2017, 06:01:55 AM »
Chessie not that I have been able to find,I installed my last starter on a 4106 GM a couple of months back those things are heavy for us older folks
chessie4905
« Reply #6 on: December 05, 2017, 06:08:19 AM »
I wonder how many starters are burned up from trying to start with bad or weak batteries.
« Reply #7 on: December 05, 2017, 06:21:15 AM »
95% would be a good guess IMO
Oonrahnjay
« Reply #8 on: December 05, 2017, 07:23:22 AM »
     For a long time, I've said that the best way to kill a good battery is to use it to power a bad starter and the best way to kill a good starter is to power it with a bad battery.  *Both* of them have to be in good shape to last a long time.
« Reply #9 on: December 05, 2017, 08:17:18 AM »
I have a jumper solenoid to connect the 2-size 31 starting batteries with my 2-8D Lifeline AGM house batteries. This serves two purposes. One to charge the house batteries going down the road, and to jump the starting batteries if you need help starting.
The starter used for the V730 is a left handed starter, and make sure it is sealed because the bell housing is wet with transmission fluid. Good Luck, TomC
