May 20, 2013, 04:36:23 AM *
Author Topic: mci 8 door window  (Read 717 times)
4shore
« on: May 02, 2007, 05:34:57 AM »
I need to replace the window in the door of our 78 mci 8, I was wondering if anyone has done this and how difficult was it. Does the peninsula replacement window fit well?
« Reply #1 on: May 02, 2007, 06:19:38 AM »
We replaced our door window with a Peninsula window.  Installation was very easy and a perfect fit. Applied a layer of the butyl rubber caulk included with the window, set the window in place, and installed the inside trim pieces. We like have a window that can be opened for ventilation.  Jack
« Last Edit: May 02, 2007, 06:22:47 AM by JackConrad » Logged
Dale MC8
« Reply #2 on: May 02, 2007, 05:18:57 PM »
Mine WASN'T a perfect fit. Problem was only cosmetic tho. On the outside front bottom corner there was a gap. Called the factory and was advised to fill gap with cut-to-fit piece of wood. BUT, just layed a piece of black air hose in there and it looks good.
The way I did it.
Dale MC8
Dale MC8
In Theory, theory and practice are the same.
In Practice, they aren't.
« Reply #3 on: May 03, 2007, 04:33:56 AM »
After reading Dale's post, I remembered, We had the same thing. I made a piece of aluminum to fill the void on our window. I had forgotten about this. Jack
