February 20, 2018, 11:40:09 PM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Trip to Crawfords/Jake installation  (Read 8186 times)
« Reply #30 on: September 19, 2007, 07:05:29 PM »
Hi Richard,
I'm set at .059 cold.
Rads are in and I will be leaving here in the am.
Hope this helps
nick-
If you get a chance, do a test. While the engine is still somewhat cool, try the Jakes and see how they operate. Then after the engine is up to temperature do the same test on a similar grade if possible.
I found that the cold test that the Jakes worked significantly better than after the engine was up to temperature.
Based on that I changed the clearance to .055 and realized significantly better Jake action after the engine came up to temperature.
Pages: 1 2 [3]  All   Go Up
