April 26, 2018, 12:53:51 AM *
Author Topic: Drilling through laminates  (Read 1064 times)
tekebird
« on: August 03, 2007, 12:12:34 PM »
I am wanting to install some drawere locks.
the drawer fronts are covered in a laminate?
what would be the best method of drilling these?
any special drill bit?
cover with tape like you do for sawing?
thanks in advance
NEWELL in South Carolina
« Reply #1 on: August 03, 2007, 12:17:24 PM »
Eliminate/ minimize the relief angle behind the cutting part of the drill bit. That will reduce the self feeding ability & minimize the chance for grabbing & tearing hunks out.
Another idea is to clamp a piece of plywood to the surface & drill thru it all together. that really works best, even on fragile items.
Hank
« Reply #2 on: August 03, 2007, 12:47:27 PM »
I would use a good quality and sharp forstner bit. They're made from about 1/4 up. They're not designed for metal and if you hit a nail or screw you'll mess it up. They work best in a drill press but can be used successfully with a powerful enough hand held drill (not really a problem if you're drilling under an inch). The biggest challenge is keeping the bit square to the work when doing it freehand. Clamping two pieces together is a good idea but hitting your mark accurately can be a problem if that's an issue. You don't use a pilot hole with forstners either.
What I always do when in doubt is try whatever I'm about to do on a scrap to see how it behaves.
Hope that helps.
cody
« Reply #3 on: August 03, 2007, 12:57:03 PM »
I drill laminates on a regular basis in our cabinet shop, the way we do it is to mark the hole with a felt tip marker so it'll show thru masking tape, then use a sharp center punch to center the hole and pierce the top layer of the laminate, then drill a slightly undersize hole with a cobalt bit, then the exact size with another cobalt bit, the masking tape will help keep the chipping to a minimum. You can make a center punch for laminate by taking a nailset and sharpening the point with a grinder.
tekebird
« Reply #4 on: August 03, 2007, 01:10:53 PM »
thanks All
