January 15, 2018, 11:55:40 PM *
Author Topic: glue for installing siding?  (Read 2322 times)
ttomas
« on: August 05, 2007, 08:27:52 AM »
 I raised the roof of my MCI9 and have decided to install fiberglass sides. What would be a good glue to use. I will use rivets also. thanks Tomas
TomCat
It's 4:20 somewhere...
« Reply #1 on: August 05, 2007, 08:37:14 AM »
I used SikaFlex to attach the 20ga steel to the sides of my Thomas. Works very well.
Jay
87 SaftLiner
Connel
Eagle 05 w/Ser60 & HD4060PR
Day Eagle landed & before total rebuild.
« Reply #2 on: August 05, 2007, 08:38:30 AM »
Tomas,
This website might offer you some information.  Has been used by many on this board.  They also have a #221 that is used by some.  Have not personally used it but will be doing so in the next couple of months.
Connel
http://www.sikaindustry.com/ind/ipd-transoem-body
Central Oklahoma
Refuse to have a battle of wits with an unarmed person.
prevost82
82 Prevost 8V92ta 6 speed
82 Prevost Marathon XL
« Reply #3 on: August 05, 2007, 10:23:47 AM »
I used SikaFlex to glue my fiberglass sides on the bus.
Ron
Cary and Don
« Reply #4 on: August 05, 2007, 09:04:12 PM »
We will be doing this soon.  My question is, do you need to do the rivits also?  And how many and where did you put them. There is something about using just glue that makes me a little nervous.
Don and Cary
GMC4107
Neoplan AN340
1973 05 Eagle
Neoplan AN340
« Reply #5 on: August 06, 2007, 03:04:21 AM »
If it were me, I would use rivets along the top, just under the drip rail. Also midstream above the aluminum, most is covered up there by a piece of molding.
Good Luck and Happy Trails,
H3Jim
« Reply #6 on: August 06, 2007, 07:05:17 AM »
and make sure you clean the surfaces per sikaflex specs.  for example lacquer thinner will leave a film thatwill cause the adhesive not to stick.
Jim Stewart
tekebird
« Reply #7 on: August 06, 2007, 07:13:34 AM »
if I were doing the job I would use 3m 5200
it's a marine grade adheasive and will almost certainly never fail.....your metal next to it will likely fail first.
prevost82
« Reply #8 on: August 06, 2007, 10:01:48 AM »
I put rivets on the top and bottom about every 4"
« Reply #9 on: August 18, 2007, 11:42:42 PM »
I saw a bus where the owner used silkaflex and rivets.  The metal was ever-so-slightly bulged out between the rivets that were spaced 4 inches apart.  It looked odd and a little homemade.  The silkaflex is strong enuf to not need thye rivets but how are you going to keep it clamped?  I don't know what caused the bulging but I think he used a large bead of cement and a smaller one was called for.  Don't know though.
ttomas
« Reply #10 on: August 19, 2007, 07:59:52 AM »
I've done one side and it really worked well. I used 3M 8609.I only put rivets on the top and bottom of the siding. (one 35' piece of fiberglass) I was advised to use it by a supplier and another long time bodyman. I tests ed it first and have since used it for various other applications. It is costly, but forms a permanent bond. The materials bonded are the weaker link. Tomas
Sammy
« Reply #11 on: August 19, 2007, 08:48:26 AM »
Sika makes many types of adhesives and sealants. I have used it on transit buses and MCI's too.
Make sure you use the right product for your application. The website is in a previous post.
It's awesome stuff.
Good luck.  Cool
ArtGill
« Reply #12 on: August 19, 2007, 09:31:04 AM »
I had good luck using Sika. I installed 1/8 inch alum with no fasteners.  To apply pressure, I parked my coach next to a building and used 2 x 4's to wedge between the building and the panel.  I also used small plastic spacers that are used in ceramic tile to keep the bead from being compressed too much.  It has been five years and no problems.
Art
Art & Cheryll Gill
Morehead City, NC
jjrbus
MCI5C/N Ft Myers FL
« Reply #13 on: August 19, 2007, 03:48:56 PM »
Good point Art. When useing adhesives like Sika, 3M ect. it is necessary to not squeeze out all the adhesive. Contact manufacturer to find out how thick adhesive should be for maximum strength. Not how thick it should be applied, but how thick it should be for maximum bond.
 Buck riviting something that has adhesive applied squeezes out the adhesive! Why put something on and then sqeeze it all out?
« Reply #14 on: August 19, 2007, 04:04:11 PM »
Someone on the board bought several thousand little plastic washers to use as spacers. Last I heard he still had a lot left, Maybe sold them by now. Think he was in Colorado, but can not remember his name now. Oh well, getting old.
