im looking for some new defrost blower motors or bearing kit,rebuild kits. for the 4106 front dash. ive gutted the dash and want to fix them before i put it all back together they work but are noisy. i supposed other models will work? thanks in advance george
George -Would you be interested in a dashboard A/C for your 4106? If so, when you talk to Luke, JD or Dean's Coach, ask for the complete dash HVAC unit out of a 4905. You'll get both a heater/defroster core plus an A/C evaporator.
These are 24V, so you'd still have to get 12V motors for your '06 and swap them. Plus you'd have to do the prep work for freon lines, electrics, etc.
But then you'd have a working A/C that was built to fit under the dash!
