January 16, 2018, 03:32:25 PM *
Pages: 1 2 [3]  All   Go Down
Author Topic: 8V92 Radiators  (Read 8339 times)
« Reply #30 on: September 20, 2007, 06:51:36 PM »
Update,
The rads are now installed. And not such an easy job either.  Getting the top brackets unbolted and reinstalled was a challenge to say the least.
After replacing some hoses and tank lines, it was an 8 hour job with the three of us non stop. The good news is that the new rads were dropping
the coolant temps 70 degs. from 190 going in at the top, and 120 comming out the bottom. I'm happy!  Allthough it was only 80 deg. out today,
I still climbed some good hills with the otr air on at 70 mph and the hottest the gauge went was 180. After removing the old rads, I was able to
see just how clogged they were..
« Reply #31 on: September 20, 2007, 07:32:56 PM »
Nick,
And happy you deserve to be.  Sounds like a home-run to me....70 degree drop.  That is a great point of reference as if the engine is adding 70 degrees you must be able to drop that amt to achieve a stable condition.  Is my logic correct here?  So many have heat problems with the 92 and they seem to flounder.  If it is a rule of thumb that the rad drop must equal the engine raise and a 8V92 raises the temp 70 degrees.  There is something wrong with this logic as if you went into a 100 degree ambient then the engine outlet would be 210.  I guess the answer is that due to your inlet temp being 120 your thermostat is not wide open and hte thermostat will regulate the output to 180 till you go into an overheat problem.  I am pretty sure you are through fighting a heat problem, at any rate.
Congradulations again,
Pages: 1 2 [3]  All   Go Up
