January 18, 2018, 02:01:18 PM *
Author Topic: What is this?  (Read 2044 times)
Brian Diehl
« on: August 15, 2007, 07:23:39 PM »
This thing came off the truck I got my ISM motor out of.  It has an air line for compressed air on the bottom and an oil inlet and outlet.  Inside there is a bearing mounted cone that air is directed into.  At the bottom of the outer edge of the cone are air jets that cause the cone to rotate in around the center shaft that it is mounted on.  There are no filters inside, just this rotating cone.  What is it and what was it's purpose?
NewbeeMC9
NewbeeMC9
1981 MC9 8V71, HT 740
« Reply #1 on: August 15, 2007, 08:27:18 PM »
PCS?
Pnuematic Cone Spinner?
Interesting, can't wait to hear what it really is.
« Reply #2 on: August 15, 2007, 08:32:18 PM »
Looks like a thingamajig on a whatchamacallit over on the..........
Don't know. but it will be interesting to find out. I thought at first it was an air dryer until I saw it had oil lines. Weird.
Happy Trails,
Barn Owl
Roanoke, VA
PD4106-1063 "Wheezy Bus"
« Reply #3 on: August 15, 2007, 08:41:12 PM »
Is it one of these?
http://www.spinnerii.com/index.cfm/div/divID/40/divid/0
If you donít want it I might be interested. They use a similar type where I work and they work great. I donít think you are looking at air lines but oil lines. If you are going to put many miles on your bus you should use it yourself.
« Reply #4 on: August 15, 2007, 08:46:10 PM »
Barnowl, Very interesting thread you posted, never heard of that. Does it really work? Sounds like you have experience with it.
pipes
Tug boat dude.
I was captain on this Tugboat around Nigeria
« Reply #5 on: August 15, 2007, 08:58:41 PM »
AIR powered CENTRIFUGE ?
Stanwood WA.. North of Seattle.
05 Eagle plus air bags.
Barn Owl
Roanoke, VA
« Reply #6 on: August 15, 2007, 09:03:31 PM »
Yes, they work very well, especially on older mechanical diesels. The newer diesels are a lot cleaner so my company is fazing them out. I wish I could get my hand on the stuff that is sent to the shredder, we would all have one for free. The problem is that they donít even let you take a breath of air out of the place; I have to exhale when I go through the guard shack.
On the ones I am familiar with, you put what looks like a piece of paper around the inner wall of the centrifuge. Over time a very fine substance will build up on it due to the centrifugal force. The sediment reminds me of the powder that builds up around the shroud of a cut off saw or a grinding wheel, except itís black, not gray. When itís time to service it you remove the paper with the junk on it and install a new paper ring. I would like to get my hands on one if the price was within my budget.
« Last Edit: August 15, 2007, 09:59:19 PM by Barn Owl » Logged
Barn Owl
Roanoke, VA
« Reply #7 on: August 15, 2007, 09:05:36 PM »
No, itís not air powered. It uses the pressurized oil to spin the centrifuge.
Brian Diehl
« Reply #8 on: August 16, 2007, 08:54:53 AM »
This unit DOES have a pressurized air line at the bottom.  I don't know what the purpose of the line is though.
« Reply #9 on: August 16, 2007, 09:30:27 AM »
Brian,
This shouldn't matter but what brand of truck did your engine come from? I thought by now or resident FREIGHTLINER SALESMAN might have enlightened us about it! What about it TomC ?
Don4107
« Reply #10 on: August 16, 2007, 09:51:14 AM »
I wonder how one of these would work with two cycle Detroits.  I don't have any oil pressure to spare at an idle.    Maybe with a bypass valve that would only open when pressure is above a preset level.
Any idea what one costs?
Don 4107 Eastern Washington
1975 MCI 5B
1966 GM PD 4107 for sale
1968 GMC Carpenter
Brian Diehl
« Reply #11 on: August 16, 2007, 10:09:34 AM »
Brian,
Yep, this was on a Freightliner, 2000 Century Class Truck.
brojcol
Jimmy
« Reply #12 on: August 16, 2007, 10:24:31 AM »
Is that some kind of adjustment knob on the left side???
Lee Bradley
« Reply #13 on: August 16, 2007, 10:40:50 AM »
That secures the band that holds the clean-out cover.
