April 24, 2018, 05:52:14 AM *
Author Topic: Water System Manifold  (Read 1459 times)
mlh1936
Graphics By Turbo Images
« on: September 03, 2007, 10:30:07 AM »
Can someone please tell me where I can buy one of those water system distribution manifolds? Thanks.
Mal
1987 MCI 102A-3, 8V92, HT-740 conversion in progress.
« Reply #1 on: September 03, 2007, 10:42:22 AM »
Mal,
Pretty much everyone makes their own.
Depending on they type of tubing you use, you can go with PEX and brass ball valves, PVC and brass or PVC ball valves, copper with brass ball valves, or just about anything else you want.
I would use ball valves though as they seem to last longer and don't leak nearly as much as the gate type valves that your use to.
Good Luck!
« Reply #2 on: September 03, 2007, 10:50:55 AM »
Mal, like Dallas said you make your own or get a plumping shop to build one i have never seen one for sale i guess because not all coaches are plumbed the same
« Reply #3 on: September 03, 2007, 10:57:18 AM »
I think he's talking about a Maniblock system, but I don't know where you buy them.
Several on here have used them, so someone will chime in.
I designed and built my own using copper and brass valves. Does everything I would ever need to do, including sucking in antifreeze or chlorox, pressurizing a hose, etc. Can bypass the pump when on shore, and fill the tanks.
« Reply #4 on: September 03, 2007, 11:33:23 AM »
put manabloc in yahoo and find lots of information.
« Last Edit: September 03, 2007, 11:35:35 AM by DrivingMissLazy » Logged
KC Eagle
83 Eagle in process
« Reply #5 on: September 03, 2007, 11:44:11 AM »
I used the manobloc system, picked it up off the e-place for about $60 new. Worked out great, compact and easy to use.
