January 16, 2018, 04:55:24 PM *
Author Topic: not my best day...  (Read 4224 times)
« Reply #15 on: September 09, 2007, 07:21:56 PM »
Well JR, the upside is that I had to remove some of the rivets holding on the headlight panel to get that stainless panel off, so now I can get that new headlight panel installed after my double deer strike last December.
I've also figured out how to replace the broken plastic headlight adjusters, so will post that when I get it done. NAPA only had one set of the adjuster screws I used and I need to get some more, but keep forgetting when I'm up there.
maria-n-skip
« Reply #16 on: September 09, 2007, 07:41:49 PM »
 Gumpy,
    Bummer.......But lets take a step back.
   With a few premo brews all fixed without................ big ooooops.
   So the solution is not to start anything until after a few brews.
    I'll have to try it myself this measuring 2...cutting 3 times is getting boring.
   Skip
NewbeeMC9
NewbeeMC9
1981 MC9 8V71, HT 740
« Reply #17 on: September 10, 2007, 02:49:22 AM »
Hey Gumpy,
Nice looking honey porter.  makes issues work out easier.  Not problems just oppurtunities Cheesy  Having one first i guess falls into the "few ounces of Prevention" catagory. Cheesy
Maybe you could have used the situation to get a plasma cutter. Grin
Thanks for the sharing and hope we can at least provide moral support.
jlaney
prevost one
« Reply #18 on: September 10, 2007, 05:16:33 AM »
hey gummpy
i might be able to make it a little easter.
when i started to lower the floor in my pd 4501 sceniccruiser. started to cut the plywood on the floor with a skill saw. taking small pieces out one at a time,
i noticed something black coming out with the saw dust. quess what.  i was cutting right thru the wiring harness going the lenght on the bus with about a 120 wires . i cut about 12 feet of wire into. try going back from one end to the other end to find the correct wire to connect back.  tweed covered also.
thanks jt
j.t. laney  tyler texas 1980 prevost lemirage
« Reply #19 on: September 10, 2007, 05:29:09 AM »
I know that feeling. In July, I was helping my Father-In-Law put in some irrigation line and electric line out to his garden and where he parks his
camper and other trailers. He had rented an awesome ride on Ditch-Witch. I was pumped cause I'd never run a machine quite like that. We put
in about 600 feet of trench and laid the lines and electric and I started backfilling. The I remembered he wanted to put in a gutter drain off
one corner of the house. It had to cross the newly laid water and electric, but I knew they were deep enough in that area and the gutter drain
was only going down about a foot. So, I'm digging along and look back to see a big gush of water coming out of the digging chain. Yep, right through both the new water and electric lines!
Now that's what I call a missed opportunity. If I'd cut the main harness in the middle of the bus, I would have had to cut the bus in half and lengthen it by 5 feet to fix it. Especially if it were an awesome Scenicruiser!  Shocked
Fredward
« Reply #20 on: September 10, 2007, 08:31:34 PM »
I can't wait to see what we cut through when we install the tail light conversion circuit board. Plus I usually have Summit in the fridge in the front bay: to be used for medicinal purposes only.
Fred
Fred Thomson
« Reply #21 on: September 11, 2007, 05:14:19 AM »
Fred
We'll start with the Summit. Installation should go much easier, then.
Fredward
« Reply #22 on: September 11, 2007, 07:14:05 PM »
Craig you are truly a man with discerning tastes. Would we have time next week to tackle it? (I'm asking myself as well) With the weather forecast upcoming, I might have to move it into the heated side of the shop!
Fred
Fred Thomson
« Reply #23 on: September 11, 2007, 07:24:00 PM »
Let me check my calendar...
Hmmm...
Oh, look, I'm free!  Nothing on the calendar. No work. No life. Just me and my bus.
Yep, anytime next week should do. Let me know when.
Christyhicks
« Reply #24 on: September 11, 2007, 07:48:12 PM »
So, you wanna hear about the "Larry and the cat burial" story? Huh Do ya?  I've probably told it before. . .
Oh, whether you do or not, here goes. ..if you've read it before, just ignore the rest of this post:
So, the neighbor's dogs were running loose, and while we were away, they broke in through our patio door screens, killing my beloved cat.  As you can imagine, I was pretty upset when we returned home, (the dogs were still inside the room), so I called a police friend and Margie, in that order.  When the police officer offer to "dispose" of poor Moose's body, Margie, seeing the look on my face, wisely suggested that perhaps I would prefer that Larry bury him for me.  I suggested a spot under our Rose of Sharon trees, and we lovingly prepared a small box for him.
Now, I gotta tell you, Larry is like the typical guy, and even though we had three different sized backhoes within a couple of hundred feet, did he grab the smallest one, (which, I still insist, was more than adequate to to the job  Wink. . . ) NO!  He brings down the big, 27,000 lb, JCB 1700 B, extend-a-hoe.  Roll Eyes  He claims he was simply trying to get the job done quickly and as painlessly as possible.   Cool This simply wasn't meant to be.
The first scoop he takes out pulls up the drain line from our main geothermal system.  Well Crap!  So, he walks on up around the house and comes in and tells me he had a little problem.  I asked him if he shut the system down and he hesitates. . ."well, no. . . ".  Oh, crap, crap.  Shocked I run for the thermostat, and then downstairs to confirm what I feared, yep, sure enough, now that the outlet of the drain was 6' up in the air outside, all of the water it was putting out was pouring right onto the floor of my woodshop inside!  Arrrrrggh.  Angry  Cry
Ok, we've had enough trauma, so, between he and Margie, they get Moose into the ground carefully and quickly.
The next morning, he decides he'd better repair the drain line, so that we can turn our geo back on.  He takes another scoop and proceeds to drag up our water supply line from the well out of the ground.  Crap, crap, CRAP.   Angry Angry Angry
By this time, it's clear to me that if he had used the little backhoe, he would have had to work a heck of a lot harder to drag those lines out of the ground, but he's not buying.  We finally agree that I need to watch for him as he digs to repair BOTH THE DRAIN AND THE WATER SUPPLY, cause GOD only know what else is lurking under the ground for him to hit!
By the time we got all the repairs done and covered up, our teeny tiny little gravesite was large enough to have buried a herd of buffalo! Cheesy Geeze.  Christy Hicks
NCbob
"Foolish Pleasure" 35' MC5A
« Reply #25 on: September 11, 2007, 08:31:23 PM »
 Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Grin Grin Grin Grin Grin Grin Grin Grin Grin Grin Grin Grin Grin
Gawd A'mighty Christy!  If it weren't for poor Larry you wouldn't have any excitement in your life! Wink
Soooo good to see you post on the Board again...it's been toooooo long!
NCbob
« Reply #26 on: September 12, 2007, 03:33:09 AM »
Gosh Christy, That story was too funny! Tell Larry to use a water finder next time he decides to dig, stick or coat hanger works great.  Grin I'm sure glad Larry chose the right tool for the job.  Roll Eyes
I'm sure there will be lots of similar stories around the campfire this week in Texas.  Tongue
See you Thursday,
Green-Hornet
« Reply #27 on: September 12, 2007, 12:47:04 PM »
The power of homebrew is not to be taken lightly!
That could have been a disaster if the bundle was cut through. Thanks for sharing that with us.
I have been a homebrewer for about 15 years. Another rewarding hobby Grin
Hi yo silver
« Reply #28 on: September 12, 2007, 03:45:47 PM »
Tell ya what...if I give up the bus search tomorrow and decide not to be a bus nut any longer, I'll still read this board for the rest of my life just to see what happens next! LOL  I don't know what stupid story to tell on myself first...
Dennis
Christyhicks
« Reply #29 on: September 12, 2007, 05:44:56 PM »
Well, I'm sorry, but you left it wide open. . . we actually have decided that a Backhoe is a "Dowser" for Larry Wink. . . really, ANY tractor works when he's on it.  It's the TRUTH! Grin
The other day, for instance, he was lowering the dirt on the west side of my new garden building, so that water flows around it instead of trying to run back at the house.  Sure, we've got some underground feeder lines for my watering system, but they are about 2' deep, with only one, count 'em, ONE, water line that comes up shallower right at the edge of the hill. . .which goes on up the hill and stays about 12"-18" deep at all times.
Guess which line Larry found?  Roll Eyes Yep!  That was with a box blade, going, juuuuuuust a tad bit deeper than the 4-8" I suggested he remove.  I guess the tractor's pretty noisy and when I said he "only" needed to be about 8" deep at the most, he heard, "make it about 8" deeper than the foot you've already gone!"  ha ha.
Oh well, that's what they make primer and glue for!  Luckily, since we do plumbing too, we have lots of pipe, fittings, glue and primer on site at all times. . . and people ask me why we decided to do plumbing! Wink Cheesy  Christy Hicks
