June 20, 2018, 12:29:39 AM *
Author Topic: Pocket Door  (Read 6268 times)
maria-n-skip
« on: September 09, 2007, 07:53:41 PM »
 Well after two weeks messing around building one of the two pocket doors needed
 I finally got one up and satisfatory.
   Lessoned learned:
   2-3/4 inch sheets of plywood covered with Formica get very heavey. I didn't want a flimsy door.
  I think the thing could handle a light load .357. I don't really think I need a Safe room.
  So the next one will be honeycombed with 4" holes to lighten it up.
Skip
« Reply #1 on: September 09, 2007, 09:14:44 PM »
Skip,
When we got our PD4103 it had been converted by Custom Coach, (one of their first).
the bathroom door was made from 1" marine grade exterior plywood with formica on both sides. It was held up with a piano hinge screwed into the edge of the plywood with 5/8" brass screws every 2".
When we took it down we found that it weighed close to a hundred pounds!
Since that time, various pieces of it have been a desktop, other pieces have been used as a base to run power tools on.
I never have figured out how it lasted all those years with the piano hinge holding it up!
NewbeeMC9
NewbeeMC9
1981 MC9 8V71, HT 740
« Reply #2 on: September 10, 2007, 03:13:26 AM »
Instead of holes,  how 'bout an SIP,  layer foam insulation with thin plywood on each side then formica.  Strong, light weight, sound dampening,  foam is a little cheaper than plywood too.  could use paneling etc.
do it your way. Smiley
Dallas,  I guess we underestimate piano hinges, spreading the load helps,  or they just don't makem like they used to. Wink
maria-n-skip
« Reply #3 on: September 10, 2007, 06:50:52 AM »
 Dallas.....Nice to see nothing goes to waste. 1" desktop boy you could rebuild V8 engine on that Wink
 NewbeeMC9,
              I would love to build foam core doors I just haven't worked out how much foam to put in
   so it doesn't blow out the plywood or leave big air pockets. Do I leave vent holes for the extra to come out?
   More investigation I'm sure.
 Skip
rip
« Reply #4 on: September 10, 2007, 07:10:29 AM »
Skip;
       If you use the right track weight is not a problem.I used Hettich track on my solid cherry doors with raised panels on one side and full length mirrors on the bath sde.They are heavy but the rollers can take the weight and they can't come off the track.Been travelling fulltime over 4 years and no problems. My wife insisted on full length mirrors.Not my idea.
                      Don
Kristinsgrandpa
« Reply #5 on: September 10, 2007, 08:19:13 AM »
Skip, at one time I was going to make foam core pocket doors.
I planned on using the blue Dow foam, sandwiched between two pieces of 1/4" oak paneling with a small oak frame around it.  Contact cement or liquid nails should hold it.
I believe the foam is available in 1/2" thick pieces. That would make the door about an inch thick.
Ed
maria-n-skip
« Reply #6 on: September 10, 2007, 08:34:27 AM »
 I must be slow this morning... I was thinking of spray foam not sheet foam.
   Go figure; that would be a lot easier...Smiley
  Skip
prevost82
82 Prevost 8V92ta 6 speed
82 Prevost Marathon XL
« Reply #7 on: September 10, 2007, 10:40:23 AM »
I made my pocket doors with 3/8 plywood with mirrors on both sides with a raised boarder cap around the edge, 1 3/8 total thickness. They are heavy but the track seem to be holding up and we haven't had any problem with them.
Ron
« Reply #8 on: September 10, 2007, 10:46:23 AM »
I used a standard 1 3/8" hollow core oak for ours, cut it down to the proper height, used standard pocket door hardware and frame, also cut to size. Very light and easy rolling. I will see how it holds up, been in for about a year now.
FWIW,
TomCat
It's 4:20 somewhere...
« Reply #9 on: September 10, 2007, 10:51:04 AM »
I have three pocket doors, all hand made, 6 panel, solid red oak, 3/4 inch thick. Nice and solid, without being too heavy.
Jay
87 SaftLiner
ol713
« Reply #10 on: September 10, 2007, 12:42:31 PM »
Hi;
   I have a solid pocket door yet to be installed.
   How do you secure it while on the road?
                           Thanks,   Merle.
maria-n-skip
« Reply #11 on: September 10, 2007, 12:52:17 PM »
Merle,
  Closed...I have a pocket door latch from one of the wood supply internet shops.
Open....I have seen cloth with snaps or at the back end on the stop velcro glued.
            I don't know how long that would last.
            you can also install the latch on the end off the door like double french doors have.
   There are a lot of ways; it is just how you view it.
  Skip
« Reply #12 on: September 10, 2007, 01:02:05 PM »
Here is how we latch our pocket doors (both open and closed).  This photo also shows the corner of the panel door I made. I used 5/4 oak for the frame with 1/4" oak plywood for the panels.  The edges of the door frame were milled using a set of panel cutter bits on my router table. This gave me a nice looking, strong, yet lightweight door.  Jack
maria-n-skip
« Reply #13 on: September 10, 2007, 01:20:44 PM »
Jack,
   Very nice job!
 I have become a big router supporter with all the things you can do with one!
 Skip
DavidInWilmNC
« Reply #14 on: September 10, 2007, 01:30:22 PM »
How are you guys using pocket doors on buses with non-raised roofs (except for later models that have more headroom)?  I'd love to have pocket doors, but I can't sacrifice the room to frame to get a straight surface.  It seems like there's too much curve in the ceiling to mount some sort of track directly on it.  Has anybody successfully installed a pocket door without framing down any?  I seem to remember a while back somebody had a door that slid on drawer slides...
David
