April 19, 2018, 10:52:36 AM *
Author Topic: Using Aluminium instead of Copper for high amp 12v  (Read 5331 times)
niles500
Niles500
ROSIE
« Reply #15 on: September 12, 2007, 08:25:04 AM »
Stan - I believe the use of Copper is required for branch/distribution sub-panels w/o disconnects - if there is a main disconnect and lugged panel, Aluminum should be fine.
On the other hand, Aluminum wire in any installation involving vibration and the posibility of large temp. variation is a no no (as said before) - JMO
(\__/)
(")_(")
- Niles
NEWELL in South Carolina
« Reply #16 on: September 12, 2007, 09:50:02 AM »
. . . . and my personal opinion is that the quality of components used and the quality of workmanship made a big difference.
BINGO
In college we studied the aluminum wire & causes of failure. The quality of workmanship could have prevented most, but the window for getting it right was small & the smallest things could lead to failure.
In spite of this, I listened to the counter guy that assured me that 'EVERYONE" was using alum for service entrance.  Sad
Once a year for several years after I installed the alum wire from the meter to the house panel , I'd have to re-torque the connections inside the house panel, but never in the meter can.
I looked for a difference & what I noticed is the meter base on my house has a large heat sink at the lugs, the breaker inside the house panel does not. I'm guessing the heat made the biggest problem at the connection. & yes, I did use the proper no-ox paste & a torque wrench as per the instructions with the breaker that was rated for AL-CU  Grin
HB of CJ
« Reply #17 on: September 12, 2007, 01:59:29 PM »
Hello Nissan_down_unde
Yeah, about the same answer.  Large aluminum solid wire may not like vibration like experienced in a motorcoach.  May crack at the tight bends bent into the aluminum.  Also, check to seesss if all the contacts are alluminumm also and not steel or copper or an incapatability may set in including continunity problems, corrosion and the aluminum coating the other contacts.  How comes you speel words funny?  Smiley Smiley Smiley
Nissan_DownUnder
« Reply #18 on: September 12, 2007, 09:22:59 PM »
Giday HB of CJ (& others)
Thanks again for all the advice.
Strewth Mate, ifn u think I speel funy, ur lucky ur'nt trying t ntrprt mu accent.
Bewdy cobber,
         Peter
Peter
Nissan UA440,  Wellington, New Zealand
Hi yo silver
« Reply #19 on: September 13, 2007, 09:10:31 AM »
Kyle's last statement is important.  Components used with aluminum wiring should be clearly marked AL/CU, indicating they are designed for use with either aluminum or copper wiring.  The electrolysis thing re. mating dissimilar metals.
Dennis
