April 22, 2018, 03:29:57 PM *
Author Topic: What is a good price for a remain water pump 8v71 not including shipping  (Read 2014 times)
johnjem
http://photobucket.com/johnsgmc4905
1970 gmc 4905
« on: September 24, 2007, 06:05:09 PM »
need to order a remain water pump for my 8v71>I have got 1price of 250.00 not including shipping what are the other prices out there ,just want to get a idea of what there going for??
Never stop thinking,it"s what keeps us going till tomorrow
bubbaqgal
« Reply #1 on: September 24, 2007, 06:52:48 PM »
They usually run $250 up to $400 so yours is a pretty good price.
Faith is not believing that God can, It's knowing that God will.
bobsw
« Reply #2 on: September 24, 2007, 07:47:21 PM »
I just paid $264.81 for one for my 8-92 . Their was a $217.25 core charge.
73 MCI-7
pvcces
« Reply #3 on: September 25, 2007, 07:05:54 PM »
johnjem, I seem to recall that the pump is repairable on the engine by installing a kit. Have you checked on this possibility, yet?
I haven't tried it myself, but I was surprised to learn that it was possible.
Depending on the age of your engine, it looks as though you might need to replace a cam gear because they changed the number of teeth during production. My reading of section 5 of the engine manual leads me to believe that seal or pump replacement might need to be done at the shop.
For what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
kingfa39
« Reply #4 on: September 26, 2007, 10:29:35 AM »
Mine was leaking, put a inexpensive kit in it 10 yrs ago no more problem, and the good part is you dont have to even remove the pump , you can put the kit in it on the engine, easy to do, id try that before i bought a new one, as best i remeber it took about a half hour to do, a new impeller and the seals . callthe dealer and try to get a kit.
Frank Allen
4106
jlaney
prevost one
« Reply #5 on: September 26, 2007, 01:08:59 PM »
hello from texas
my water pump started dripping one night in arkansas. i called several places and one road service. i could have had a mechanic come out to replace it. but price was in the 300 400 range.  after running the engine the nest day it quite leaking ,stop and it would leak again,. i decided to drive it back to tyler tx. and took the bus to my mechanic. he pulled off the front plate on the water pump and replaced the seal all for about 60.00 . still working god after a couple of years.  you can do the work your self. thanks jt.
j.t. laney  tyler texas 1980 prevost lemirage
johnjem
1970 gmc 4905
« Reply #6 on: September 26, 2007, 05:30:52 PM »
yes i had already removed water pump due to the front case cover<the cover the water pump bolts to and front engine mounts to> to replace cover due to it had a crack in it <and i had the part already installed the new cover and wala craked again in the same spot i know oil only splashes in this cover so i am going to use some jb weld to seal this crack,so since the water pump was off i was going to replace it!
« Reply #7 on: September 27, 2007, 12:30:17 AM »
JohnJem,
Why are they cracking?  Mating surface uneven?  Gasket material not removed?  JB Weld is GREAT stuff.  I would seal it with the part installed as you might crack the Weld when you install it if it is cured as you did the new item.
2 cents
johnjem
1970 gmc 4905
« Reply #8 on: September 27, 2007, 04:58:21 AM »
i realy dont know why it craked?.I installed cover tighned all to spec, half hour later i hear crack< can i use the jb on the outside as well as the inside rub it in the crack?
« Reply #9 on: September 27, 2007, 07:18:29 AM »
If it was me I would remove the cover and find out why both are cracking in the same location, there has to be a reason. I really think it would bug me if I didn't know what caused the cracking. There has to be an uneven surface somewhere. I think the bus gremlins will haunt you if you don't.  Wink
Just my 2 cents,
« Reply #10 on: September 27, 2007, 11:03:46 PM »
Lar,
Lay a bastard flat lile on the surface that the cover mates to and work the file.  You should see cleaning scratches where the file makes contact.  Move it around to cover all around the mating surface.  I may not be clear, the file is laid across the mating flange and makes contact on two points.  Then lay it along the flange and do the same thing.  If you have studs...remove them for the filing operation.  When you find the high spot (and you will!) you have to file it down flat with the rest of the flang.  A small patch of old gasket will be enuff to crack the cover.  Use rtv silicone with the gasket and goop up both sides.
Yes!   apply the JB to both sides and work it into the crack.  Pile it up on the outside to about 1/8 inch deep and 1/4 inch wide or more.  That stuff has sealed rads for me and they lasted years.  You have to put it on still soft and use the silicone and make that the final assembly and wait for everything to cure.
Way I'd do it, anyway.
johnjem
1970 gmc 4905
« Reply #11 on: September 28, 2007, 04:18:31 AM »
thanks john ed thats just what i did so far no problem all is good thanks
