January 22, 2018, 02:29:54 PM *
Author Topic: Lethal towed  (Read 4551 times)
Stan
« Reply #15 on: October 04, 2007, 05:58:08 AM »
Paul: Turning is one of the reasons for the crossed chains. With the chains in an X configuration, they can be almost tight. When you turn, one chain gets slack at the bus end while the opposite chain gets slack at the car end.  Try drawing it out on paper.
Component parts of the tow hitch (both ends) that are permanently bolted or welded to the vehicle frame are considered to be part of the frame. There is really no excuse for any part of that ever coming loose. Improper installation or lack of maintenance is not an excuse. The legitimate failure points are the coupler ball or mount failing and the pivot points where the tow bar connects to the car.
Note that some tow bar companies cover their butt by putting short cables around the pivot pins between the tow bar and the base plate. Two piece coupler balls have been illegal for many years. Use a 2" ball with a 1" stem machined out of a solid piece of steel and design the bus hitch to be close to the car height so that a big offset is not required on the stinger.
« Reply #16 on: October 04, 2007, 07:27:12 AM »
Stan,
Thanks for clarifying on how it's supposed to be done.
superpickle
« Reply #17 on: October 04, 2007, 09:42:11 AM »
Does make me wonder just How the old fart had it hooked up  Huh
I have seen peeps with Both chains dragging and sparking like hell , made me very un easy to be close to them , for sure...  Roll Eyes
We will ALWAYS be at the mercy of the IDIOTS that think they can use Cruise to go in the back and make a sandwich...  Angry
Support Global Warming:
Drive an SUV.
« Reply #18 on: October 04, 2007, 07:49:44 PM »
Paul,
I don't know who started that nasty rumor! It is a bold face LIE!! I do not go to the back to make a sandwich! I don't even have a fridge!
I set the cruise so I can go to the back and pee! LOL!
superpickle
« Reply #19 on: October 04, 2007, 09:20:37 PM »
Paul,
Oh... OK, thats Different.. NEVER MIND  Grin
Drive an SUV.
« Reply #20 on: October 05, 2007, 05:22:11 AM »
     What is everyones feelings about safety CHAINS vs. safety Cables?  We use cables. I think I heard or read somewhere that cables are less apt to snap or break under a hard load than a chain.  Opinions, comments, BTDTs?  Jack
NEWELL in South Carolina
« Reply #21 on: October 05, 2007, 06:16:57 AM »
Depends on the cable or chain size. Either is fine if they are properly sized for the application.
I saw a s&s with what looked like a dog chain for safety chains - I hope he never needed them!
I was told by a state trooper that the SC law did not require safety chains - only required the towed vehicle must remain attached to the tow vehicle. There is no reduction in responsibility if the towed vehicle separates from the tow vehicle regardless of the safety chain use or lack there of.
Personally, I cross the chains under the hitch to cradle the trailer tongue if there is a separation.
« Reply #22 on: October 05, 2007, 07:18:09 AM »
I thought everybody did this. Also the chains should be tight enough to prevent the trailer tongue from touching the ground if it comes unhooked. As long as the chains are crossed, it is impossible to get them too tight.
« Reply #23 on: October 05, 2007, 07:32:41 AM »
  We use the coiled 3/8" diameter safety cables (6000# rating). We wrap the coils around the arms of the towbar and cross them under the hitch before attaching them to the bus. I tested this configuration by connecting everything then unhitched the towbar and pushed the car backwards. As the cables tightened up the towbar remained off the ground about 2" below the ball on the hitch.  Jack
Stan
« Reply #24 on: October 05, 2007, 05:37:23 PM »
At least one member was not aware of crossing the chains. I think the second part of your sentence is only true if the chains are equally spaced at both ends. If they are wide spaced on the towed vehicle and close to the ball on the towing vehicle you need a little bit of slack.
« Reply #25 on: October 05, 2007, 05:52:39 PM »
That would be me.  Grin I have never towed anything behind our bus, or even towed a car behind anything. So this is all new and good information for me. Someday we might tow a toad, so this will help. Thanks for the information.
