January 16, 2018, 11:07:59 PM *
Author Topic: installing air condition in front  (Read 3455 times)
jlaney
prevost one
« on: May 22, 2006, 02:21:55 PM »
hello from texas
i have an prevost le mirage , i left the road air in place, wife say's she is not going to freeze or
burn up in this bus as she did in the 4501 gmc. i have an aux air mounted in the rear to help the
carrier . i am thinking of some ways to move the evaporater to the dash area, if someone has gone
thru this please give me your imput. thanks j.t. laney
j.t. laney  tyler texas 1980 prevost lemirage
FloridaCliff
"The Mighty GMC"
« Reply #1 on: May 22, 2006, 04:50:35 PM »
JT,
Are you wanting to move the existing evaporator in the rear?
Add another to the existing one?
Cliff
Mark Twain
jlaney
prevost one
« Reply #2 on: May 22, 2006, 07:36:54 PM »
hello cliff
i have one in the rear of bus but its to big to mount in the dash, i was thinking about using the
orginal blower and adding a coil . i don't have any overhead cabinetts to hide one in, the compressor
is mounted on top of the aux gear box for the radiator fan.
i may have to modify the dash to acomadate the new coil and fan, thanks jt laney
FloridaCliff
"The Mighty GMC"
« Reply #3 on: May 22, 2006, 08:29:55 PM »
JT,
You may be able to pick up a blower and coil from a SUV or van with rear air from a salvage yard.
They are small and should fit under the dash with no problem.
The rest is piping and the the usual evacuating and recharging.
You probably could leave the rear one in place and add the extra freon for the new one.
On the SUV/vans they use the same compressor with a switch that passes the gas through the rear evaporator on demand.
Cliff
Mark Twain
niles500
Niles500
ROSIE
« Reply #4 on: May 22, 2006, 09:29:48 PM »
JT - look for a totaled Excursion/Expedition - great candidates - be sure and scavange the remote switches/t-stats - HTH
(\__/)
(")_(")
- Niles
jlaney
prevost one
« Reply #5 on: May 23, 2006, 05:44:34 AM »
hello from tyler tx
 thanks for input on front air. if the rear coil can be mounted in a vertical angle it may work.
i will also look in salvage yard for parts.  thanks j.t.laney
phil4501
« Reply #6 on: May 23, 2006, 11:50:25 AM »
So...now thqt you guys have worked this out, let's hear about the 4501 cooling that you used to have. Was factory bus air way overkill? I was thinking about fixing mine
jlaney
prevost one
« Reply #7 on: May 23, 2006, 04:25:49 PM »
tyler tx
the pd4501 139 was a 1954 scenicruiser which ran for greyhound for 20 years and converted to
a country music band bus and was run out of nashville for about 25 years . frenchy burke used it
on most of his tours.i wish the old bus could talk or may be best not  to, i think it run a lot with
willy back in its younge years. it had a 15 kw diesel water cooled gen set when i bought it in 98 and
three top airs and road air was still in it, which i took out and later took the gen set out to make room
for my guitars and such, it takes a lot of room to carry 30 guitars . six banjos , dobros and tent and such.
sure miss the old dog, thanks j.t. laney
tucsontattoo
1962 4106
« Reply #8 on: May 23, 2006, 05:53:35 PM »
Check out hotrodair.com. They have 2 or 3 opptions. Good stuff good prices.
                                                              Tucson
we do things three ways,good,fast or cheap. PICK TWO!
