April 25, 2018, 07:21:33 AM *
Author Topic: what is the best stuff to seal windows  (Read 2506 times)
johnjem
http://photobucket.com/johnsgmc4905
1970 gmc 4905
« on: September 30, 2007, 03:44:40 PM »
i had 2 remove 1 window to get behind the bathroom shower to run some wires and now i need to reseal it intill next time what is the good stuff
Never stop thinking,it"s what keeps us going till tomorrow
« Reply #1 on: September 30, 2007, 04:15:56 PM »
I use butyl rubber tape. Available at most RV Service & Parts stores.  They usually have both putty tape and butyl rubber tape.  They look almost identical (both grey and about 1/8" thick X widths of 1/2" to 1"), but the butyl rubber works much better.  Jack
H3Jim
« Reply #2 on: October 01, 2007, 12:31:02 PM »
I have been very happy with Dichor - sealer adheasive used on rubber roofs.  Seals anything, permanently.  Available in tubes from any RV dealer.  About $6 a tube.
Jim Stewart
Zeke1
« Reply #3 on: October 08, 2007, 12:26:56 PM »
Sikaflex 252 is a urethane based adhesive/ sealant that comes in 10.5 oz. caulking tubes. It sets up fast and strong, and stays flexible for expansion and contraction. It's amazing stuff. You can order it from Ellsworth Adhesives. 1-800-888-0698.
DavidInWilmNC
« Reply #4 on: October 08, 2007, 01:41:00 PM »
I'm with Jack about the butyl tape.  It's not 'permanent' like some of the other sealers, which sounds like what you need (for future removals).  One tip about using it... keep it fairly cool prior to applying it.  It's sticky as hell when it gets hot!  In fact, I try to remember to keep in in the house so it's usable when I need it.
David
johnjem
1970 gmc 4905
« Reply #5 on: October 08, 2007, 04:10:06 PM »
will the butyl tape keep its shape i need a sealent that will fill voids and gaps i dont think the tape will do that will it??
houndbus
HoundBus
« Reply #6 on: October 08, 2007, 05:08:58 PM »
Has anyone tried RTV silicone for putting windows back in...or is it not flexible enough... Thank you
PD4106-736
Milford, OH (Cincinnati area)
« Reply #7 on: October 08, 2007, 06:41:38 PM »
If Sikaflex was used wouldn't the window never come out again?
For johnjem, Butyl tape is available pretty thick if need be.
« Reply #8 on: October 09, 2007, 07:46:14 PM »
The PO sealed my 4104 windows with Silicone RTV and they not only are permanently sealed but I can't even get to the silicone to cut through it. Silicone cuts easily but this setup is inaccessible.
At least they don't leak, but I'm in big trouble if I ever need to replace a glass panel.
houndbus
HoundBus
« Reply #9 on: October 11, 2007, 05:49:32 PM »
thanks, Gus.  I used the stuff that penninsula glass (HB300..hard to work with..never sets up by design) sent to install mine except for one where I could not get to the inside to install all the screws in the trim ring.  I used RTV silicone in the hopes it would hold the window in but had some concerns
PD4106-736
johnjem
1970 gmc 4905
« Reply #10 on: October 12, 2007, 03:28:39 PM »
if u have to replace a window most come with new gaskets anyway  i think? so just cut away i am going to use a product called phonoseal it is black adhesive and also a silicone base!
